解签 - Decipher of Divination lots from Temples
ZhouXingXing
Yes indeed. During the first month I joined this company I felt uneasy already and many things happened which lead me to believe my boss is waiting for time to kick me out.
My time is running out and I still can’t find a job. when I asked GYM whether I can find a job in the next 3 months, I get sheng bei. Does this means this 3 months my chances of getting jobs are higher.
Is there any advice regarding my job search per the 3 lots? Thanks
Read HWZ Forum Rules!
Yup.. it mean you got pretty high chance of securing a new job within the mentioned period.
it did not mention about your job search but it seems like you wont get fired or asked to leave.
winteriscomin
Oh man, i assumed xiaobei and yinbei are the same = no shengbei, when i was there last week. is it ok to go GYM temple to ask again after a few days with this new info in mind?
also is it more accurate to ask for 3 shengbei as compared to 1? Or theres no difference..
thank you..
Foetid
thank you..
u just need to be very sincere and focused concentration when asking if u wish to follow the new method. dont have strays thoughts when asking
Hi shifu, kena lot 6 and 95 when asking if should accept new offer. Number 6 lot shengbei one time only but number 95 sheng bei 3 times. So which one to believe? And what is the meaning ah?
dappercivility
Steps for using sheng beis (2 red wooden blocks) to ask questions 。
a. Light incenses and stand infront of Gym or the God of the temple (not facing 天公) , intro yourself, your purpose of visit and your questions.
Report your Name, DOB with Time (Use 农历 lunar calendar if possible) and would like to ask a question pertaining to XYZ
b. After putting the incenses into the temple urn, proceed to one side of temple and wait for about 15-20 mins (This allows GYM or the God of the temple to check on your issues). Meanwhile, you can think through your questions - Many tend to skip this part which is not advisable.
c. Take lot tin and sheng beis and proceed to the prayer section (if any).
d. Inform GYM/God of your question.
Example it is a question of which options (A or B) to choose is better for you.
e. If option A is better for you, please give me 1 or 3 sheng beis and you start throwing the sheng beis.
f. Regardless of the results, you take the sheng beis and proceed to ask if option B is better for you.
g. After 2 throwing the sheng beis for 2 options, if option A has sheng bei and option B does not have, it means Option A is better for you.
In event, both options have same results as both sheng beis or no sheng beis. Proceed to draw lots by following the draw lots SOP to see what GYM/God wish to tell you about your questions (usually got hidden issues that you are not aware of)
h. Note down the lots received and let us know the results of asking questions using sheng bei method and the lots received so we can decipher for you.
Example:
Ask about option A and B, both got no sheng bei and draw lot received lot 2 and lot 98.
How to use the sheng beis aka 2 red wooden blocks?
As per the picture above.
For using 3 sheng beis as yes, you have to achieve 3 continuous sheng beis for the 3 throws at first attempt.
Meaning, first throw = sheng bei, 2nd throw = sheng bei and 3rd throw = sheng bei.
When you get a xiao bei at first throw, you can retry again and also rephrase your question to be more direct and clear so Gym or the God can understand what you trying to say. If you tried 3 times and get all xiao bei, it mean they do not wish to answer your question. You can try asking again like in 1-2 weeks later.
I learnt something new today. Didn't know have unsure bei. Thanks for sharing 🙏🏼
winteriscomin
Hi shifu. I drew 3 lots for a question. Was later told by a temple staff that the way i drew is wrong when i collected my lots. Said that rejected/successful lots all need to put back in the tin before drawing a new one. Said that it is their temple rule.
now i am confused 😅
ZhouXingXing
now i am confused 😅
Can follow our sop because the temple staff also not sure of the actual procedure because if you put back the rejected lot back into the tin and there is chance where it will come out again, so are you going to ask and verify the lot again using sheng bei when it was previously rejected ? tbh it doesnt make sense..
btw which temple is that?
winteriscomin
i agree. Because im still on the same question.
the kwan imm temple at waterloo st. The staff let me collect the lots but emphasise the method i use is wrong.
ZhouXingXing
thank you..
The xiao bei will mean no if you are verifying if the lot is the one that Gym or god wish to give you..
If you are asking questions like yes no type of question, it mean the way you put it is not clear or understandable by Gym or God of the temple.. Its not applicable for verifying of the lot is the correct one..
i see
winteriscomin
now i am confused 😅
I asked GYM for general advice on career progression from this point onwards, as it is not doing well right now (stagnant, difficulty w job search and etc).
I got Lots 81, 22 and 32. May I ask what is the interpretation from these lots? Thank you..
ZhouXingXing
For your question, these 3 lots say by this year between aug to early nov, there should be some improvement or changes despite you are feeling the current situations are not so optimistic. Just continue to keep trying and soon you will see the results..
If you have been looking for job actively, it could mean that your chance is coming soon and have to keep sending resumes.
dappercivility
I have always wondered who was the one who wrote all these 100 guanyin lots and how did guanyin sync with these 100 lots to give the readings. It's amazing when you read the lots
Enola88
extreme bad lot
勒马持鞭直过来
半有忧危半有灾
恰似遭火焚烧屋
天降时雨荡成灰
一首比较不吉利的签诗。
当前遇到的困境比较严重,
需要面对不小的挑战和危险。
即使有所缓解,损失也不可避免。
建议小心谨慎,尽量减少损失。
AUTUMN&WINTER
Can also draw lots for others. I drew lot for my 'iron tooth' ( non believer) family member about job. He sent a resume to a very good company recommended by a friend. Waited for months still no news. Very accurate. The lot said after 春天。Really, he got that job after CNY. Waterloo St Guan Yin Temple. He's still an 'iron tooth' who only believes in Waterloo St Guan Yin Pusa after this.
