- Sep 16, 2018
Does this mean that if I have a Ubiquiti Dream SE, as long as the ONR is set to bridge mode, I can use the Dream SE as a router? What type of WAN IP does it receive from the ONR? Is it a public IP address or a local IP address assigned by the ONR?
I'm still uncertain which telco I should choose. It seems MR is the only telco that is compatible with the Dream SE.
Yes your UDM SE will receive a public IPv4 address on the WAN if you connect it to the bridged port of the Singtel ZTE F8648P ONR.
But your information is not correct with regard to Starhub.
MR is using XGS-PON ONT for the 10Gbps plan.
Starhub -- you can choose to use ONT or ONR with the 5Gbps/10Gbps plan.
Reference
https://www.starhub.com/personal/store/broadband.html
1) Starhub 5Gbps at S$45 per month -- default is using Nokia all-in-one ONR with wireless AX6000 but you can go to the shop and request to change to ONT. I will recommend to go with this option (ONT) since you have UDM SE.
2) Starhub 5Gbps plan at S$55.30 per month -- using ONT + TP-Link EB810v
3) Starhub 10Gbps plan at S$69.95 per month -- using ONT + TP-Link EB810v
4) Starhub 10Gbps plan at S$59.05 per month -- using Nokia all-in-one ONR with wireless AX6000
