- Sep 16, 2018
Hi sorry noob question here, will Asus ZenWifi XD6 work well with WC ONR? Mine is a 5 room BTO, so the ONR will be in the DB box, one XD6 unit placed in my living room near the TV console, and the other unit in my Masterbed room, it should be sufficient?
Considering we mostly only need good wifi coverage in living and master room.
And also I am using Global Protect VPN for work purpose, I believe should not have any issue with WC? Was considering SImba 2.5g plan, but worried there might be issues with CGNAT.
Yes, WC 2.5Gbps should be okay with your use case.
