- Sep 16, 2018
1) Singtel recommended way to use 5Gbps -- that is with HB810.
2) But then they offer cheaper plan without the HB810. Some users may not have 10G capable device but they can still use the 5Gbps plan as an aggregated 5Gbps plan.
3) Example using Asus AImesh
Singtel XGS-PON ONR (in DB box) 10G LAN port -- Asus TUF-AX6000 in AP mode (main AImesh node) in living room (up to 2.5Gbps)
Singtel XGS-PON ONR (in DB box) 1G LAN port -- Asus RT-AX3000P AImesh mesh node in main bedroom (up to 1Gbps)
Singtel XGS-PON ONR (in DB box) 1G LAN port -- Desktop PC in study room (up to 1Gbps)
4) Example using a 2.5G switch with 10G uplink + Asus AImesh, 2.5Gbps in all rooms, combined bandwidth is up to 5Gbps
Singtel XGS-PON ONR (in DB box) 10G LAN port -- 2.5G Swtich (in DB box) 10G uplink -- room LAN ports (up tp 2.5Gbps each port)
Living room LAN port -- Asus TUF-AX6000 in AP mode (main AImesh node) in living room (up to 2.5Gbps)
Main bedroom LAN port -- Asus TUF-AX4200 AImesh mesh node in main bedroom (up to 2.5Gbps)
Study room LAN port -- Desktop PC in study room (up to 2.5Gbps)
