- Sep 16, 2018
Hello Master Xiaofan, thank you for the reply. i took up the Singtel 5Ggps offer 2 weeks ago and comes with the Singtel Wifi 6 Router and a pair of Singtel WiFi 6 Mesh Extenders.
The mobile game im playing is honor of kings. I have checked with my friends and none had my issue. At the same time, i did a speed test on both of my phone Andriod(Poco F3) and Iphone 13pro respectively. Both of them showed the below results
At the same time, able to guide me which gaming router i should be getting? Hopefully something that is most bang for bucks(and maybe something furture proof). Or do you think i should upgrade to WiFI 7 instead? It comes with TP-Link HB810 at $16.80/mth.
Thank you once again.
Looks like no issues with the Speed but latency is the problem. You may check with your friend to see if they have the similar latency issues or not. 200ms+ latency is probably not good anything gaming. You can also check with your friend what kind of router they are using.
Even though I do not like Singtel provided mesh solution, I am not sure if it is the issue this time. So it is better to optimize the placement first to see if you can have some improvement.
Total latency --> wireless related latence (you can improve this one) + Singtel latency to the server (you can not do much here)
Please post your floor plan with details of the placement of the SIngtel ONR, LAN ports in the rooms if any, the location of the main wireless router (run in AP mode) and two Singtel mesh extenders. Make sure you place the router in a proper place.
SIngtel/Starhub/M1 have some simple guides on router placement. You may want to take a look to optimize the placement of the main router.
https://forums.hardwarezone.com.sg/...home-networking.6653421/page-3#post-149371244
More importantly is how you connect the Singtel Mesh Extender? Are you using wireless backhaul? If you use wireless backhaul (the mesh extender is connected to the main wireless router using wireless), then that can be the major problem.
Do you have LAN ports in the rooms? Singtel provded mesh solution is low end dual band mesh solution and really only suitable for those with LAN ports in the rooms.
