Monitor uplorry.. any recommendations?
CaiPuDan
use for wfh and casual gaming. prefer 2 x hdmi ports. budget within 300. prims+ good?
mamboeidos
eh.... correct place to post meh?
Anyway my monitor also up lorry over the weekend and i got the acer predator XB273U
an updated version of my previous monitor which i am happy with and price ok to hoot.
3 years on site warranty
wongkc
If not fussy Prism+ is ok... I got my C315Max 2yrs ago... now the side got some pinkish bleeding liao... cheap cheap so cannot hiam... just use for work so no need swee swee...
Eost002
Dont support local brand. Local brand is just oem with different branding.
charliebrown
do u really need high refresh rate boh?
use to waste $ then realize i only surfing... :crazy:
edmwing
Prism consistency is bad. I bought 2 monitors put side by side the colour and contrast is off. Exchanged 1 and still off. Sold off on carousel and bought xiaomi.
Can Or Not
Prism their made is quite bad. Their plastic feels cheap and mine QHD monitor already has a red hue, don’t know when will uplorry. I buy because their QHd is considered cheaper than other brand one lah
Vanyel
i recently bought 32" samsung dunno what fast ips for $488.00 for my boys
looking okies so far~
5adisticD3vil
only use prism if you have no expectation
those type that goes can use is can already
simi quality this and that is dun gib a fk
cheap, can use is good enough for you
if you is this type of person, then you will lub prism
1ndigoJinx
In before OLED superiority, true blacks, peak brightness, minimal input lag. Cons include burn in, etc
poooooo
No difference, most don't even make their own panels. Just go for good warranty support.
