loganrunning
- May 12, 2017
ST's DNS is quite fast, 1 of the fastest of all the ISPs in SG, but not up to date
don't they sync it?
when i was still on ST many years back, i remember their dns takes quite awhile to update. I remember I was changing some domain stuffs and they took awhile to update.don't they sync it?I remember my systems used to sync up 2x per day, by default.
ya, up to 48hrs was their lead time i think.I'm not privy to ST servers, but i remember by default, my old hp-ux, solaris (fka sun OS) boxes had sync 2x a day, so changes locally took place within 24 hours, overseas took a bit longer for changes to propagate. Was this ST's lead time?
at later job, as customer, my isp also had the same update frequency. of course, we all want it quicker than that, like within 5min![]()
With the Xiaomi BE5000, can reach more than 1200Mbps with PC. So likely it is ZTE not handling Dual Wan Load Balancing well. Although I contact Starhub to reset the IP due to DHCP server cannot fetch the IP address.Have you tried to enable Dual WAN Load Balancing?
I think it is okay if you already bought Xiaomi BE5000. It is capable of Dual WAN Load balancing. WC users have tested it for the performance.
https://forums.hardwarezone.com.sg/...band-provider.5494964/page-105#post-152698060
On another issue unrelated to the DNS server. many years back my email was hosted by ST bizmail. after i moved my emailhost to another provider, I had issues where clients whose email were hosted on ST bizmail kept trying to send to my company email on bizmail even though I have shifted away for a few months already.
has to ask my clients sent to a gmail and i set the gmail to auto forward to my bizmail as a work around for a year
ST wasn't much help since I wasn't their customer anymore
domain + email hosted on ST. this was in the beginning. Thankfully I owned the domain and moved both the DNS and email away from themi'm not familiar with st bizmail. did it mean hosting on their platform, under their domain? if so, i usually avoid these, for the reasons you state. best to own the domain and find providers where you can just point your dns/web/mail servers to. Easier to change providers, keeps them on their toesanyway, i'm out of that game for a long time, so have not kept up. Glad you managed to find a workaround singtel
Have you done basic troubleshooting etc. to possibly isolate the possible issue?For those who are using Starhub 1Gbps, have you experienced any slowness recently? My home wifi speed seem to slow down quite a bit for the past 2-3 weeks. I did a speed test to see the difference between wired and wifi connection, and the latter is so cui leh (less than 100Mbps). I don't know if this is normal. The router I'm using is Linksys EA8100.
Before I head to the long call waiting process with Starhub for help, is there anything I can troubleshoot or do to improve the speed? The only thing I did was follow Starhub' instruction via whatapp to restart router and ensure nothing is blocking the router.
Might be the Linksys EA8100 issue too or your PC/laptop/client.
Honestly if it doesn't affect your normal usage (watch video loads relatively okay at an acceptable qulity, no real dely when loding webpages. I would say save your sanity and live with it. Wifi is affected by Way too many factors, some of which are out of your control even.I tested on another laptop and on my phone. Used another cable connecting the router and the NucleusConnect device. Although the router has been in the current location for ages, I moved it to another location for testing. The results were similar. Unfortunately, I don't have another router to test. Can't think of anything else le.
I believe Starhub should be the most successful in moving their customers from legacy plans, followed by M1.Just wondering who are still using legacy Starhub plans based GPON technology -- 500Mbps, 1Gbps and 2Gbps.
I guess most of the users have migrated to XGS-PON based plans: 3Gbps/5Gbps and 10Gbps, discussed in the following thread (originally for Starhub 5Gbps plan, started on 29 April 2024).
https://forums.hardwarezone.com.sg/threads/starhub-ultraspeed-3gbps-5gbps-10gbps-plans.7024290/
There are still some Singtel 1Gbps/2Gbps plan users.
https://forums.hardwarezone.com.sg/threads/singtel-1-gbps-fibre.5930834/page-268
But many Singtel users also migrated to the new 3Gbps/5Gbps/10Gbps plan (initially for Singtel 5Gbps plan, started on 18 May 2024)
https://forums.hardwarezone.com.sg/threads/singtel-3gbps-5gbps-10-gbps-enhanced.7030365/
For M1, they just stopped offering 1Gbps plan recently. So there will be still quite some M1 users using GPON (500Mbps, 1Gbps and 2Gbps). Therefore they still use the same thread for the discussion.
https://forums.hardwarezone.com.sg/threads/m1-fibre-broadband-discussion-part-2.5658375/
The following combined XGS-PON based plans thread was created by me on 23 July 2023.
https://forums.hardwarezone.com.sg/threads/new-10gbps-5gbps-6gbps-3gbps-xgs-pon-based-plans.6930337/
Singtel launched XGS-PON based 10Gbps plan in Jan 2023 but very expensive at S$193.80 per month.
https://www.hardwarezone.com.sg/mob...test-10gbps-home-fibre-broadband-plan-updated
Starhub followed in Feb 2023 and the price was at S$119.90 per month. But Starhub was more aggressive to reduce the price faster than Singtel.
https://www.hardwarezone.com.sg/mob...d-subscription-starting-today?ref=exploremore
M1 was very late in the game.
