NightRaven49
Not sure if I can compare using my current MSI modern 14 laptop, which has an 8GB iGPU. It is using up 85% of my 16GB RAM and 2GB GPU when loading valorant and browser in the background. Valo also lags quite alot. Will a 32GB ram with iGPU solve the issue? Or will it only be solved with a separate GPU?
the modern 14 uses intel 10th gen u series, which has a very dated igpu and far behind the amd u/g series, but since u mentioned 2gb gpu i suppose u also have the mx330 on it? cant tell if ur using the igpu or dgpu to game, but either way would be suboptimal. the igpu was already fairly weak when it launched 4 years ago, so naturally performance would be low if u are gaming on it. but if ur using the dgpu to game, allocating 8gb to the igpu is effectively throwing away that 8gb of ram to do nothing as u wont be using it at all, while the remaining 8gb is left to run the game, background programs and the rest of ur system. that is likely not enough and causing the lags. if i were u, id try to find a way to allocate less ram to the igpu (likely through bios, maybe 512mb is enough) so the system has most of the 16gb to work with, and ensure that games are run on the dgpu (which is much faster than the igpu), see if things improve before considering an upgrade.
if u do decide to upgrade, u can go youtube and find gameplay of the games u play on these apus like the 5560u/5600g, valo easily does 150fps with 1% lows around 100fps at 1080p high settings, which indicates a smooth experience (reflected in the recorded footage). 32gb ram will definitely help to ensure ur system has enough ram even if u allocate 8gb to the igpu (overkill), and ddr4 is fairly cheap nowadays. imo a modern dgpu to play these kinds of games is too overkill, especially if u dont use a high refresh rate monitor, and would be a waste of money.
Current build
MB:B550 tomahawk
Cpu:5700X
Upgrade
Cpu: Ryzen 7700
Usage is bt streamfab keepstream download upload files unzip zip files mainly for files gaming yes 3 AAA no fps games.
imo i dont think its worth it to upgrade to the 7700. for gaming, the 57x3d gets very close (compare 7700 and 58x3d fps numbers) and is a drop in upgrade. aaa games are also generally very gpu heavy so cpu is not that big of a factor in performance. unless u feel that the 5700x cant zip/unzip ur files fast enough and u do it on a regular enough basis to be able to save time going from zen3 to zen4, i think there would be little benefit in the short to medium term spending so much on a platform upgrade. if u really want am5, best to jump to the 78x3d directly and u should be set for the next few years.
Upgrade
MB: B650 Tomahawk wifi/ X670 Tomahawk WiFi Or B650 As rock steel legend
I don't know which motherboard to go and steel legend look like a good picks but i am a little scare of as rock bios. I am more a msi person but tomahawk this version board look like got boot time laggy?
if dead set on going am5, i feel msi boards are not very well equipped for the price they are asking. the asrock steel legend has pcie gen5 enabled primary x16 slot and nvme, which is already better than the b650 tomahawk which is stuck on gen4, and is probably cheaper too. i would only go x670 if i really need those extra pcie slots. ddr5 memory training on am5 is also largely a non issue at this point, just remember to enable some bios settings [1] [2]. but again, i would advise u to stick to am4 especially if ur more familiar with msi bios.
Current build
Cooler. Arctic liquid cooler ii 240 (2 years old)
Upgrade:
Cooler: Arctic liquid cooler 3 240
if the lf2 is still working well, no point replacing it as the gains are very minimal. u would basically be spending $130 to shave at most 1-2 deg c (emphasis at 12:38), which i feel is not worth it. yes the lf3 may be the best thing, but the lf2 gets u 95% of the way there and u dont have to spend anything extra.
Current build
Psu: seasonic focus gx 650 (4+years old)
Upgrade:
Psu: seasonic focus gx 850
unless u experience unexpected shutdowns while using ur current 650w unit, im not sure i see the benefit of replacing it with a higher wattage one given that ur reusing ur gpu. maybe only to get a fresh 10y warranty, but ur current unit is not even halfway through.
Is there a big diff in performance between the mATX and ATX versions of the board? The VRM performance is worse? Will there be a big impact with the 7800x3D?
the vrm is massively cut down, going from 14 60a power stages to 6 50a power stages. the vrm also has a significantly smaller heatsink, resulting in much higher operating temperatures with a 7950x. but performance should not be affected with the 78x3d, since it barely pulls any power. i did help build this 78x3d + b650m pg lightning combo in a y60 case recently, so far no performance complaints, and at least the y60 mounts the gpu vertically to hide the empty space that the matx board doesnt fill.
Any advice on how to decide between 8600G or 5600G? I know that 8600G means faster performance and future proofing (though idk if I will actually know how or want to upgrade parts in future) while 5600G is a cheaper option.
AMD RYZEN 5 8600G 3.8GHz 8CORE/16THREAD
ASUS TUF GAMING B650M-E WIFI
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
~$900
or
AMD RYZEN 5 5600G 3.9GHz 6CORE/12THREAD
ASUS TUF GAMING B550M-PLUS WI-FI II
NEO FORZA MARS RGB DDR4 3600MHz CL18 KIT 32GB
~$700
AMD WRAITH COOLER PRISM RGB
CRUCIAL P3 PLUS 1TB GEN4 NVMe M.2
SILVERSTONE ET650-650W V1.4 80+ BRONZE
COOLER MASTER CMP320 ARGB BLACK TG
3 X 120MM ARGB FANS
id settle for a 5600g build for under $600 or mini pc for even less as originally recommended to u, since cost seems like a priority, and either of those will do the job just fine. the 8600g doesnt really make a lot of sense given u can get a 5600 + 4060 build for the same or less money, which would be a whole lot faster, and u mention that u are not too sure about the upgrade path (which is a key selling point of am5). or just try out fixing ur laptop first as advised above; ur 2nd post did come before my response above since i do try to limit my posts on this thread to once a day so i can one shot reply many in one post, i know i will spam reply otherwise since i do check here frequently :s22:
I'm planning to build a 7800x3d with 4080 super to play black myth: wukong at 1440p max settings and upgrade to RTX 50 series in the future.
in that case, better to wait for 50 series. most of the 50 series probably wont beat the 4080s and thus wont be an upgrade, and the parts that are likely to actually provide an uplift (eg 5080, 5090) are launching within the next 6 months.
wishfulpeacherino
Thanks for the advice! Will think about whether I want 5600G or go for the 5600+4060 or even cheaper GPUs like ASUS GeForce RTX1650 4GB or MSI GeForce RTX3050 6GB VENTUS 2X OC. Any relevant difference in performance between 4060 and the cheaper GPUs?
Also, assuming I don't suddenly play high demand games, will this built be durable? Like the parts won't break down in one year right hahaha
I just learnt that prebuilt PCs are sold at a discount as compared to fully customised ones (I was calculating based on the pricelist and the 4060 will increase the budget by a good $450)
RockaRolla
Do not go for the GTX 1650 or RTX 3050 6gb, you are purely wasting your money , its like upgrade machiam never upgrade
If 4060 is a stretch, can try looking for rx7600 pre-built instead or if you wanna diy, theres a cheap gigabyte rx7600 from techyard
deepblue_82
nonono rtx 1650 or rtx 3050 nooooooooooo
unless u are not gaming.. if u are gaming u should go no where near them...
5600g is a cut down cpu... i would u rather for for 5600
on amz now there is a770 under 400 or a rx6750xt at 400
jrwong84
Thank for the reply [SIZE=14px]NightRaven49[/SIZE] reason wanted to upgrade part of reason is i can see zen 4 going down in price and the 7700 can get $320. For motherboard yes I do agree on the steel legend is around 30% better than msi tomahawk guess i will go for the steel legend.
As for Psu I intend to always buy new one when reach 5 year it been a habit when I first started building pc 15 years ago. Yes i know 10 years warranty but I always scare about Psu may fail my others pc part it somethings happen lucky this habit so far no fry my parts for the 15 years building.
For cooler yes you are right will stick back to the old one.
TThanks you for the time.
R6exR6
Question: For liquid-cooled GPU in a custom loop, .....
a) can the GPU be upgraded?
b) bring to PC shop to upgrade?
c) cost how much more to upgrade compared to just swapping out air-cooled GPU?
astroboy82
I'm planning to build a 7800x3d with 4080 super to play black myth: wukong at 1440p max settings and upgrade to RTX 50 series in the future. Is the following build good?
AMD RYZEN 7 7800X3D 4.2GHz 8CORE/16THREAD
ASUS ROG STRIX B650E-F GAMING WIFI AM5 ATX
LIANLI GALAHAD II TRINITY PERFORMANCE 360MM
Team T-Force 6000mhz 32Gb CL30
ASUS ROG STRIX GeForce RTX™ 4080 SUPER O16G
WD BLACK SN850X 2TB GEN4 7300MB/s NVMe M.2
CORSAIR RMx SHIFT RM1000X-1000W ATX3.0 PCIe5
LIAN LI Dynamic Evo RGB BLACK
120MM Fans ARGB x7
I'm also thinking of getting LIANLI O11 Dynamic Mini instead.
What is the price? I also looking about the same spec.
NightRaven49
its either u go for the cheapest option (5600g) or the fastest option (5600 + 4060). as u mentioned, the 4060 is not a big top up from the 5600g only; both the gtx1650 and 3050 are much slower than the 4060 and i doubt they will be that much cheaper. but i highly recommend u try to fix ur laptop first as per my previous post, if it is set up correctly it should still handle ur use cases well.
all the parts are from well known brands with minimum 3y warranty, i wouldnt worry about it.
true, but for the price u are paying for cpu + mb + ram i dont think the uplift would be enough to feel like a worthwhile upgrade. then again, i prefer to keep my hardware running as long as possible, hence the above opinion and also my advice to wishfulpeacherino to give their laptop a chance before making a big purchase. if u hand itchy then by all means.
a) yes can, it would be easier if ur new gpu block is compatible with ur current fittings and ur not using hard tubing.
b) if not sure how, best to bring to shop.
c) the difference is generally the cost of the waterblock and any additional fittings if required, though u can mitigate this somewhat by opting for a cheaper gpu model (provided that is also compatible with the block).
Jeffrankko
Like to seek all the experts here on whether to upgrade parts or buy a total new system:
My current build of more than 5 year old:
AMD Ryzen 5 3600 6-Core 3.6 GHz
MSI B450 TOMAHAWK MAX AM4 ATX
Seasonic FOCUS Plus Series SSR-650GX 650W 80+ Gold
Teamgroup T-create Expert DDR4 32GB (2 x 16GB)
Zotac GTX 1070
Adata XPG SX8200 NVME (512GB)
I am looking to change the following parts (willing to buy new or 2nd hand whichever that is more cost saving):
CPU: 5700x3d
GPU: 6800XT or 7700XT
SSD NVME: New 1TB/2TB NVME
Not sure if I need to change my PSU to a higher watt one to support the new GPU.
Trying not to spend more than $1K or if above that should I just go for a new system?
Koenig168
CPU: 5700x3d
This looks like a good plan though I would suggest holding off on the GPU purchase unless you need it urgently or can get a good deal on a used card. The new GPUs from AMD and Nvidia should be coming out in the next few months.
dyns1992
Hihi,
my desktop died for the 2nd time, figure it is time to change to new desktop
currently looking at invader pc MASTER M15
AMD
RYZEN 5 7600 3.8GHz 6CORE/12THREAD
MSI B650M GAMING PLUS WIFI
KINGSTON FURY BEAST RGB 6000MHz 16GB(8GBx2) CL36
SAPPHIRE AMD RADEON PULSE RX 7800XT
SILVERSTONE ET750-G 750W 80+ GOLD
NEOTEZ DEUS CASING
4 X 120MM ARGB FANS
HIGH-SPEED AX WIRELESS AND BT | WIFI 6 + BT 5.2
WIN 11 UN-ACTIVATED
RAM UPGRADE 4:
CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36 x 1
SSD UPGRADE 1:
CRUCIAL T500 PRO 2TB 7400MB/s GEN4 NVMe M.2 x 1
total at SGD $ 1,501.00
should i upgrade any part?
or any suggestion will be helpful
thanks in advance to the shifu
one more question, am i able to transfer my window license from my dead desktop?
deepblue_82
Zotac GTX 1070
CPU: 5700x3d
if u can get a 2nd hand 6800xt around 350 then its worth it.
if not u can wait for the next gen in a few months as this gen really freaking overpriced
dont think u need to change ur psu at the moment.
the cpu u can get at aliexpress
the ssd just look out for sale... now and there got 1 tb sale
deepblue_82
am4 8 years on its still very much viable...
such a cool thing by amd...
its kind of like the old day of Phenom days
NightRaven49
6800xt is faster than the 7700xt and packs more vram. while u cant find it new anymore, it is also generally cheaper. 650w is also sufficient for either.
1k is just about enough. if u want to go for a brand new system, u would be looking at spending at least 1.3k on a 7600 + 77xt build, and even then the parts offered would be not that great.
the more midrange cards tend to take a while to launch. getting current ones now still isnt too bad an idea.
RAM UPGRADE 4:
another $30 for rgb and tighter cl30 cas timings on the teamgroup kit might be worth it.
if u are able to retrieve it, then its worth a shot.
MangoCAT
Add on
alot of things can find on PCmasterrace reddit de
The PSU tierlist is worth learning
Not mean gold rated mean is good cos parts
MangoCAT
A good tip is want to be a pc gamer --> PC enthu --> Pc masterrace, need to study abit. Cos linux is wow
