1. 15354 btuAm planning to change a system 2 for my 2 room condo ?
Is it better to use 2 x system 1 or a system 2?
What are the rated BTU for these compressors ? Tried to find but couldn't get those numbers.
1. Mitsubishi Electric MXY-2H20
2. Mitsubishi Heavy Industries SCM60YSW
3. Daikin M50VVMG and M75VVMG
Thanks in advanced !
2. 20472 btu
3. 14331btu and 20472 btu
system 2 or system 1 depend on:
- if you can tahan the heat or waiting for the repair guy to repair.
- who will be servicing the FCU?
- there will be 2 set of trucking (unless you want 2 set of system 1 to share a single trunking, which then what the point of getting dual system1) .
- 2 isolator is needed for dual system 1
- dual system 1 small repair will cost more ( cause you got 2 set ) but you save on the big repair like pcb board ($600 to $800) so might as well get a new system 1 at 1.2 to 1.4k
SM: system 2 is around $2,561 vs dual system 1 (9k + 9k btu) $1,253 X 2 = $2,506 vs dual system 1 (9k + 12k btu) is $2,735
for system 1 SM 12k btu, it standby power is around 4kWh for a month or (1kWh is 0.32 cent, so it $1.28 of standby power)
