- Sep 16, 2018
Signed up for 10gbps SIMBA broadband about 2 weeks ago, so far it's been quite disappointing:
- 10gbps plan, but I'm only getting around 600mbps up/down in speedtest, it can drop to 200mbps at certain time, never been able to achieve anything higher than 700mbps, I am using AX router on MacBook with wifi 6 capability, so I'm not sure what's the issue
- Gaming on simba is really bad, it just seems like they are not able to connect to singapore server directly, and need to route through Hong Kong etc just to reach back to singapore server, so you get very high latency 100ms+ on alot of games like mobile legend etc, previously on M1 and this was never an issue.
- CGNAT, meaning you won't be able to connect back to your own network to use as VPN etc, not a deal breaker for me but useful to have when travelling to certain countries
Regret signing up, but with the 1 year minimum contract, I got no choice but to stick with it. If they don't fix this by the contract expiration, I will definitely be porting back out to one of the big 3 telco.
I do not recommend new users to subscribe to SIMBA mainly due to stability and support issues, then it has other issues as well.
1. Cannot help on the Gaming and CGNAT side.
1) SIMBA does not have good connections to Singtel and probably Starhub network as well. So that is probably the reason you are having latency issues with local gaming server.
2) SIMBA will probably not change the use of CGNAT but they provide IPv6 as a potential work-around (but that means you need to have access to IPv6 network if you want to use IPv6 for VPN or remote access back to home network). For remote access you can use things like Tailscale or Zerotier.
2. But for the first issue, you may have to upgrade your router. If your router is only capable of 1Gbps, then your will use the 10Gbps plan as 1Gbps. Many users forget about this point.
10G capable wireless routers are not cheap. SIMBA provides subsidized Amazon eero Max 7 to the 10Gbps plan users, that is probably the cheapest way to get a 10G capable true WiFi 7 router.
