HIP starting today. Very excited
Apparatus
Can only tell you - never ever select the option to put portable toilet in yr house.
You may think it convinent, but yr whole house will smell like sh*t even some days after the HIP finishes
Yah I opt that out. It's not only your urine but those workers too. Have to wake up in the night and run downstairs to the provided toilets lor
Medicated Oil
High Honorary Member
The portable toilet will only be usable in the evening.
The drain piping is not inserted to the toilet hole in the day time.
So, the worker cannot use the toilet.
I opt for it and it save my life cos I need to shower a few times due to the hot weather.
Ethan_
Like that cover up they is do what, the ceiling and floor touch up?
Apparatus
wat kind of tape u use? those will come off with paint peelings?
Talk about tapes also angry
Masking tapes - Buy those from Industrial hardware shop. They are sticky. Buy from neighborhood hardware shop expensive and not sticky. Likely the glue dried up lor
Duct tapes - Can buy from neighborhood shop
Regardless of which type there'll be instances where the tapes come off from the surface. So paint touch-up will be needed
Medicated Oil
TS, how is the feeling of having all the pounding now if you are in the house now ?
Apparatus
Floor no cover lah. The HIP workers will lay some hard paper sheet and rubber sheets during work to protect the floor tiles
Ceiling too no cover
Some of my neighbors repaint their unit after the HIP
kw442
GLHF;
Finished my HIP about a month ago.
Just FYI, the 7th and 8th day will be noisy and dusty too as they will be cutting and laying both the wall and floor tiles.
Medicated Oil
I'll go back soon soon now and then. After that go to MCD or KFC beside my block to nua
:D
You can siam the 1st 2 day when they are pounding.
Rem to stuff the gap of your door when you leave the house.
Rem to get the contact number of the foreman cos you need to hunt him down if you find any issue at the end of every day.
Apparatus
The HIP workers are now working. They put up a 2nd layer of plastic sheets as a secondary protection
The floors also covered and protected
kw442
Do you have the option to do or remove the kerb?
We decided to do back the kerb.
Morugana
1.how many years old is the hdb flat?
2.When did hdb first announced the HIP for your block?
3.And how long you waited until contractors came to start work since first announcement?
Apparatus
I asked the hacking worker and he said to keep the same kerb
Better to keep the kerb
ahnyaahnya
Aiyoh.
My HIP is due in a couple of years' time.
I go toilet frequently , especially at night.
Will it really stink?
Happened to people you know ?
Apparatus
30 yrs old. HIP is for buildings 30 yrs of age
I think early this year. Went for voting and chose the tiles
They will send you letters to inform you. Otherwise can visit the HIP office near your place to find out
