HIP starting today. Very excited
ghregular
yes absolutely. my sis was very happy when it was completed!
just bear for the moment.
sales69
Good luck with your HIP. It's not that scary.
Only first 2 days of hacking is dirty. After that is nothing much.
You will see the construction of your toilet and appreciate it more. 😃
Oh and more mingling with neighbours.
Jjxjjjyy
8-last day most important be around for defects check and rectify on the spot especially tiling , water heater install how wires runs. When u eventually remove dustproof the nightmare comes where u can’t only patch the paint that peel off when remove the tapes u need paint the whole thing
Medicated Oil
Just share with my personal experience.
Was napping at the HIP rest area with some of the aunties chatting inside.
And heard all the gossip soup that they are boiling.
Better dun mingle too much with the neighbors if they are ba po.
(Need to update my previous comment. Sound like I am napping with the aunties.)
amazingone
may want to install IP camera to observe your house when you are not at home, as some neighbours may be 'nosy' and walk in your house
Eric Ying
If I'm not wrong HIP costs 2K plus
You'll be billed once the job is completed
y so expensive , mine starting later this month two toilet , fire rating door with gate only $886.15 :crazy:
If I dont do any cover sheet myself , the contractor will put for me right ?
Apparatus
Yes, the HIP contractor will put up a plastic sheet wall for you.
Better you put up your own primary dustproofing and the HIP contractor secondary layer of protection
kw442
For the HIP?
Ours is SG + 4 room flat = $7xx (payable by CPF)
Add:
$4xx cash to upgrade to stainless steel water pipes (from the default PVC)
<$20 for 2x bidets.
Edit: We opted out of replacing the main "wooden" door.
Eric Ying
Add:
<$20 for 2x bidets.
I don’t know stainless steel pipe need to pay , was thinking using my copper pipe back cos I using gas heater.
Medicated Oil
If your original pipe is stainless steel, it is free.
If not, you have to pay.
My original piping was plastic.
I replaced them with stainless steel.
Eric Ying
mine originally is copper pipe , is copper better or stainless better?
