orwell76
- May 18, 2006
Heng chiu escape Bro orwell76!
I see sms liao fast hand fast leg off mobile settings, take out my redone backup fone
No have cos I got dual sim, thats why I off in the app instead in case I travel to other countries besides MYNot off it on your own device meh?
Really like scammers they Bro orwell76!I see sms liao fast hand fast leg off mobile settings, take out my redone backup fone
I disabled data roaming FireEmblem Bro.
Just so to specifically avoid this problem.
They ownself go activate my data roaming!
Not M1 Bro ksapplem1 is? u use before right?
once activate liao it will keep on then will "rebate" u the next month
I received this sms.
Welcome to Indonesia!
We've enabled your Data Roaming (Network) settings for you because we noticed you've not set it up. You can manage these settings anytime on *** app.
I bought malaysia data roaming 2 weeks ago for a day trip, then over the weekend went indonesia and bought e-sim instead (i didnt know the malaysia data roaming can be used in indonesia same package).
I switched on since I got the app which is years ago Bro FireEmblemSometimes in Singapore near woodlands can get Malaysia side Telco liao. Not sure when you switched off but could be switched to Malaysia roaming while in sg.
You go Malaysia so often why never get a sim card that has roaming data packaged into the price?
Red!![]()
Just state StinkTel.I dun name names cos I dun wanna kenna sue for $5.
But very dirty, I never buy roaming plan and I specifically off data roaming in their app for this reason.
They ownself activate data roaming in the app without my permission and buy the roaming plan without my approval!
Lucky they at least got sms me so I know about this purchase.
Really very smelly and dirty!![]()
Marketing. Imagine. 5 million ppl. 5miilion x 5 dollars. Every month got used no used. 25 millions inside account. Passive incomeI dun name names cos I dun wanna kenna sue for $5.
orleng is it?I dun name names cos I dun wanna kenna sue for $5.
I thought should deactivate the other sim card or disable roaming for the other sim card. Or else no count.No have cos I got dual sim, thats why I off in the app instead in case I travel to other countries besides MY
They auto purchase roaming I can understand, but they auto activate my data roaming setting without my permission that one is hacking liao
i just check my CircleLife they also activate Roaming in the app by default. seems like this tactic is not exclusive to a single telco only...I dun name names cos I dun wanna kenna sue for $5.
Their GOMO plan also, I ported to Eight and they still proceed to deduct another month from my CC, KNN. I messaged their Bot but no reply, no Support at all or numbers to call.
The $18.33 I treat it as donate to StinkTel Beggar Sect.
I off auto roaming specifically to avoid this problem Bro whatheheck!bro you autoroaming and accidentally pressed![]()
Some phones will keh kiang auto scan for best signal. My old Huawei is like this. If example you in Singapore and your Telco that time signal weak, but in woodlands as it is near Malaysia can actually receive Malaysia Telco signal one.orleng is it?
I kenna roaming charges to Malaysia while i was asleep in AMK. The ironic thing is that my work place is in woodlands and i don't even connect to Malaysia network![]()
Eight is also using Green network.I port to CMLink jitao stopped wor, Redone is using green network
Actually whats their GOMO plan for Bro Elfblade?Just state StinkTel.
