ZacharyA
- Apr 11, 2010
These BOD KF paus, must keep them in freezer?
and when ready to cook, can use microwave to heat up instead of steam?
If you buy frozen, then you have to put in freezer.
You can use microwave to heat up, but I think the pao skin will be like rock and very dry if you microwave. Just like how you microwave a bagel.
I normally use oven not microwave oven for bagels. And steamer for paos... The moisture from the steam really relaxes the pao for you to om nom nom it
