SingTel 3Gbps, 5Gbps & 10 Gbps Enhanced
What kind of speed did you achieve under Windows or Linux?
I am using the same IOCrest card.
My test results here: quite a bit better than yours but take note that I do not use any 3rd party Anti-virus programs. I may be a bit biased but I consider them worse than a virus. I use Windows built-in security utilities including Windows Defender. My Ryzen 5 5600G desktop may also be a bit fresh since I do not install too many programs, mainly things related to development, like WSL, Visual Studio 2022 and MSys2 and some other development tools, related to my Open Source projects involvement.
FYI, I got much better results with an Intel X520 based dual 10G SFP+ PCI-E card (on the x16 slot).
https://forums.hardwarezone.com.sg/...witch-and-vq-xgs-pon-onu-stick.7047645/page-7
Testing of IOcrest 5Gbe Ethernet Adapter (RTL8126 chipset) under Windows 11.
Product page: http://www.iocrest.com/index.php?id=2413
Review: https://www.servethehome.com/iocrest-5gbe-pcie-adapter-review-realtek-rtl8126-nic/
Singtel 5Gbps plan.
Singtel ONR --> Hasivo 2.5G/10G switch 10G RJ45 port
Hasivo Switch SFP+ port with Ganwen 10G SFP+ Copper module --> Windows 11 desktop with IOcrest 5Gbe NIC (Link speed 5000Mbps).
Looks like the download is not up to 5Gbe standard, upload is okay. I will test under Ubuntu 24.04 Linux later.
Bash:
PS C:\work\networking\ookla-speedtest-1.2.0-win64> .\speedtest.exe -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.45 ms   (jitter: 0.12ms, low: 1.34ms, high: 1.65ms)
    Download:  4040.67 Mbps (data used: 5.6 GB)
                  1.51 ms   (jitter: 4.60ms, low: 1.26ms, high: 206.65ms)
      Upload:  4746.34 Mbps (data used: 5.6 GB)
                  7.24 ms   (jitter: 0.53ms, low: 1.58ms, high: 13.45ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2ced5241-208f-4d2f-901b-c9674c6638fb
It turns out Ubuntu Linux 24.04 version with Linux kernel 6.8 does not support RTL8126 yet so I have to build from source. The support has been integrated into Linux kernel 6.10 and later.
Download is still on the low side, a bit better than Windows though.
Code:
mcuee@PCRyzen5600G:~/build/networking/ookla$ ./speedtest -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.65 ms   (jitter: 0.05ms, low: 1.61ms, high: 1.69ms)
    Download:  4323.91 Mbps (data used: 5.3 GB)
                  1.24 ms   (jitter: 4.27ms, low: 0.98ms, high: 205.40ms)
      Upload:  4746.28 Mbps (data used: 5.9 GB)
                  2.80 ms   (jitter: 2.46ms, low: 1.18ms, high: 227.51ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/4fc9a5d0-4983-4f03-adbf-38b1d0ba97a9
Even though my test shows that the download speed is on the lower side (may be my system issue, this is a lower end Ryzen 5 5600G system).
I think this adapter may still be worth buying at it only occupies single PCI-E x1 slot. This may be an important factor if your are using MATX or ITX mother board and the only x16 or x8 slot is already occupied by the Graphics Card.
IOCrest also has similar RTL8126 based M.2 to 5Gbe adapter.
http://www.iocrest.com/index.php?id=2410
Both are available pretty cheaply from IOCrest official Taobao shop. AliExpress price is much higher though.
IOcrest also has 10G NIC offerings for PCI-E and M.2/MiniPCI-E.
http://www.iocrest.com/index.php?catid=89
http://www.iocrest.com/index.php?catid=90
My fiber point and ONR and AP are located at opposite corner of the house from TV. I have 1 lan cable to link up the ONR to the TV box.
Last night I tried to add another AP next to my TV. Connected the LAN cable to the new AP and connected the TV box to the new AP.
It didn't work ! TV refuse to connect !! Help!! How how ??
This is a known issue, only selected AP will work, like Singtel issued router, Linksys E9450 and Netgear Orbi.
Singtel ONR -- Selected AP (must be in AP mode, cannot be in router mode) --> Singtel TV Box
I mentioned that the free Singtel AX5400 router is kind of useless, now it is useful in this use case, as mentioned in Option 3 in the below FAO.
There is another work-around to use custom AP mode if your router's built-in switch supports IGMP Snooping (option 4 as mentioned in the following FAQ).
https://forums.hardwarezone.com.sg/threads/singtel-onr-ap-issues.5778791/page-6
Just a summary post for reference.
For Singtel ONR users who have Singtel TV box and yet want to use 3rd party router, you have a few choices.
1) Connect Singtel TV box to the Singtel ONR, you may need to have two LAN ports in the TV console area
Singtel ONR -- Singtel TV box
Singtel ONR -- 3rd party router in AP mode (to avoid Double NAT)
2) Use Singtel supported router in AP mode, you only need to have one LAN port in the TV console area
Singtel ONR -- Linksys E9450 in AP mode -- Singtel TV box
Singtel ONR -- Netgear Orbi in AP mode -- Singtel TV box
3) Use Singtel Mesh Router (or Singtel AC Plus or Singtel AC Elite) as the intermediate. You only need one LAN port in the TV console area
Singtel ONR -- Singtel Mesh Router (automatically run in AP mode, you may want to disable its Wifi) -- Singtel TV box
Singtel Mesh Router -- 3rd party router in AP mode
4) Use customized AP mode
Singtel ONR -- 3rd party router in custom AP mode (needs to support IGMP snooping) -- Singtel TV box
Reference from the expert hairymonster.
https://forums.hardwarezone.com.sg/...tel-tv-onr-ac86u-ax23-singtel-tv-box.6681949/
It is also included in the sticky thread.
https://forums.hardwarezone.com.sg/...home-networking.6653421/page-2#post-145334936
guangzong
PCI-E slot is not the issue, the chipset is a x 1 chipset so it will not help you to move to x16 slot.
Rather you can get better NICs based on Intel X540 or X550 chipset if you use the x16 slot. These chipsets use PCI-E x 4.
Yeah, i have Intel X540-AT2 which i am using.
I got the IOCrest Realtek just for testing as it is not expensive.
Thank you for your responses. I appreciate it.
guangzong
Quick question please:
I set the ONR LAN5 to Bridge. I did not reboot the ONR or do a renew on the WAN.
I then set the TP-Link HB810 from AP to router mode. I rebooted it, but now i am able to access the router interface. On my PC, i could not even get the default 192.168.88.x IP. How do i perform a hard reset on the TP-Link please?
*Edit: at the bottom of the unit, there is a small hole with the words RESET. Push a pin in and i guess it will hard reset the device. It's all in black so i missed it the first time.
guangzong
Not sure what i am doing wrong here. But here's what i did to get back access.
Login to the ONR web interface and unbridge the LAN 5.
Restart TP-Link and my original network is back up.
guangzong
Edit: issue is resolved. ZTE F8648P ONR 10Gbps LAN port (LAN5) set to Bridge mode successfully with TP-Link HB810 running in router mode.
1. Using original SingTel setup, set TP-Link HB810 to router mode first.
Reboot.
Network will change to the default 192.168.88.0/24.
Configure PC/laptop IP to 192.168.88.x. Login to TP-Link web interface 192.168.1.1 and see double NAT.
Internet works.
2. Set ZTE F8648P ONR 10Gbps LAN 5 set to bridge mode. Reboot (may not be necessary but i did it anyway).
3. Refresh the web page in the TP-Link.
Under Internet tab, you should see the Public IP address.
Using this method, you should be able to use your own router connected to the 10Gbps LAN port of the ONR. In my personal opinion, if you do not have SingTel TV, nor the require the second LAN on the ONR to have internet access, this bridging of the LAN5 would be a safer and easier way to use a router behind the ONR without double NAT. You also do not have to take the risk of setting the ONR to ONT mode and causing the entire internet not to work.
Update: i confirmed with the ZTE F8648P ONR 10Gbps LAN 5 set to bridge mode, i am able to:
- Use my own ASUS GT-AX6000 router. IPv6 6rd works. Sadly, this router does not have 10 Gbps port, only 2.5 Gbps.
- Connect my PC directly to the ONR bridged LAN 5, and get the SingTel Public IP on the PC's NIC.
Discovered con: IPv6 6rd does not seem to work on the TP-Link HB810, no matter how i try.
With the correct 6rd settings, i can ping to ipv6.google.com on my PC and get a response, but i am unable surf the net, until i either:
- disable IPv6 6rd on the TP-Link HB810.
- or disable IPv6 in my network card's Properties.
I suspect it could be some IPv6 LAN routing setting, but i am not an expert in this.
I will live without IPv6 6rd until i get a third party WiFi-7 with 10Gbps ports. The current prices are simply not competitive for ASUS.
jess_sy
Anybody tried upgrading their SingTel 1gbps to higher speed even though less than 21 months? Any extra fees?
5Gbps Mesh Plan at $29.09/mth (U.P. $106.09/mth)
  • Comes with a pair of WiFi 6 mesh devices
Good deal coming from ST?:s14:
https://www.singtel.com/personal/products-services/broadband/eform/ga-dm/free2gbps
T&Cs:
https://www.singtel.com/content/dam...ements/fibre-free2yrsbb-ga-dm-letter-tncs.pdf
Edit to correct the mistake.
I re-read the terms and conditions, I think I made a mistake here. It is really meant for targeted existing Singtel TV customers.
Terms and conditions.
Promotion is valid until 08 Decemnber 2024 and applies only to the address mentioned in this letter, with an active Singtel TV plan or service. The subscription discount on the 2Gbps Enhanced Plan or 5Gbps Mesh Plan will be reverted to the plan’s prevailing rate if the Singtel TV plan is terminated. Singtel reserves the right to change models of devices due to stock availability.
Promotional 5Gbps Mesh plan at $29.09/mth (U.P. $106.09/mth): A 24-month contract is applicable for new
Singtel Broadband only.
This bundle includes a 5Gbps Enhanced broadband plan at a promotional rate of
$18.90/mth (U.P. $95.90/mth) with a mandatory Singtel WiFi 6 mesh device add-on for an additional
$10.19/mth.
Usual price of $95.90/mth for 5Gbps Enhanced Plan will apply after the 24-month contract ends.
No refund is permitted. SingNet reserves the right to replace the default router with other router models
without prior notice.
This broadband bundle also comes with 6 months of Disney+ Premium (U.P. $15.98/mth).
Prevailing monthly subscription charge applies after the promotion period
Fibre Plan includes:
Home line​
Registration fee, service activation charge and Singtel installation waiver (worth $263.25)​
Up to 12 months of Disney+ Premium (U.P. $15.98/mth applies thereafter)​
Please select your preferred Broadband plan (24-month contract applies):​
guangzong
Reboot.
Internet works.
I will live without IPv6 6rd until i get a WiFi-7 10Gbps third party router. The current prices are simply not competitive now for ASUS.
BTW, the link also includes another promotion.
Take note the offer is only for targeted existing Singtel TV users.
2 FREE years of 2Gbps Enhanced Plan
Home line​
2 FREE years of 2Gbps Enhanced Plan (U.P. $55.90/mth)
Comes with 1x Singtel WiFi 6 Router
Terms & Conditions Promotion is valid until 08 Decemnber 2024 and applies only to the address mentioned in this letter, with an active Singtel TV plan or service. The subscription discount on the 2Gbps Enhanced Plan or 5Gbps Mesh Plan will be reverted to the plan’s prevailing rate if the Singtel TV plan is terminated. Singtel reserves the right to change models of devices due to stock availability.
Lesson learned for myself --> I need to read the terms and conditions of such offer more carefully.
This offer link was actualy there previously, and only contains the free 2Gbps offer for existing Singtel TV customers. It was clear.
Then Singtel somehow added the 5Gbps at S$29.09 in the above link, I did not read the top paragraph of the terms and conditions carefully and only read the paragraph specific to the newly added 5Gbps offer.
Terms & Conditions
Typical local download speed: https://www.singtel.com/personal/support/broadband/utilities/local-speedtest.
Promotional 2 free years of 2Gbps Enhanced Plan: Customers with an active Singtel TV plan or service are
eligible to sign up for this promotion. This plan comes with a NEW 24-months contract, customers will get to
enjoy 24 months of free plan subscription on 2Gbps Enhanced plan (worth $55.90/mth). This broadband
planalso comes with 6 months of Disney+ Premium (U.P. $15.98/mth). Prevailing monthly subscription charge
applies after the promotion period.
Promotional 5Gbps Mesh plan at $29.09/mth (U.P. $106.09/mth): A 24-month contract is applicable for new Singtel Broadband only. This bundle includes a 5Gbps Enhanced broadband plan at a promotional rate of
$10.19/mth. Usual price of $95.90/mth for 5Gbps Enhanced Plan will apply after the 24-month contract ends.
without prior notice. This broadband bundle also comes with 6 months of Disney+ Premium (U.P. $15.98/mth).
Prevailing monthly subscription charge applies after the promotion period.
BTW, the link also includes another promotion. The offer was posted before in another thread.
Haha, I read back the older post in this thread, in fact, the offer did not change, but my memory failed. I was giving the correct comment when the offer was first posted in this thread on Tuesday.
Not enough of sleep last evening. :ROFLMAO:
You can take a look at previous page -- I was correct at that time.
https://forums.hardwarezone.com.sg/threads/singtel-3gbps-5gbps-10-gbps-enhanced.7030365/page-15
Singtel offered me free 2gbps for 2 years as long as I stay with Singtel TV.
Now to figure out if Nokia G240 can be bridged, but I scared they raise the price of my Singtel TV by $40 bucks after I sign this 2yrs free Internet :ROFLMAO:
https://www.singtel.com/free2gbps
This is really a targeted offer for selected SIngtel TV customers, but indeed the offer is quite attractive. Last time Starhub has similar offer with free Fibre Internet service for those who continue with Fibre TV service.
1. Offer details
Home line
2. Terms and conditions
I do not believe Singtel allows such upgrade unless they send you targeted offer through SMS/Email/Post. In that case, you may not need to be bound by the 21 months minimum subscription rule. I have never received such offer though myself (usually within two month or one month if there is such targeted offer).
But no issue asking Singtel (WhatsApp, Physical Shop, 1688, Facebook, Roadshow, etc) to see if they can accomodate your request.
SingTel just reduced the pricing of 5gpbs plan + WIFI 7 from $65.90 to $59.90
1. 5Gbps Enhanced Plan with WiFi 7 Router at $59.90/mth (U.P. $95.90/mth)
https://www.singtel.com/personal/products-services/broadband/eform/5gbps
Singtel keeps changing the contents of the hidden links. The above link contents were posted in August 2024.
The same link has totally different offer now. Now the link is only for recontract of 5Gbps for existing customers.
Link content is valid as of today 26-Nov-2024.
Singtel's All-in 5Gbps Fibre Broadband plan
(U.P $95.90/mth, 24-mth contract)
Our all-in Fibre plan includes:
Home Line​
Mobile Broadband (500MB)​
Weekday / Weekend router installation waiver worth up to $147.71 (Online Exclusive)​
Registration Waiver worth $54.50​
NLT SAC Waiver worth $61.04​
12 FREE months of Disney+ Premium on us (U.P $15.98/mth applies thereafter)​
12 FREE months of All-new Singtel TV (new TV sign-ups only) (U.P. $30.98/mth)
12 FREE months of Viu Premium (U.P $7.98/mth applies thereafter)​
12 FREE months of Amazon Prime (U.P $2.99/mth applies thereafter)​
12 FREE months of Broadband Protect (U.P $3/mth applies thereafter)​
I am a: recontracting customer
Please select your preferred Fibre Broadband Plan:
5Gbps Mesh Plan WiFi 6 + Apple HomePod mini at $73.94/mth (U.P. $111.94mth)
  • Comes with 1 unit of Singtel WiFi 6 Router + 1 unit of Singtel WiFi 6 Mesh and an Apple HomePod mini
5Gbps Enhanced Mesh Plan WiFi 7 + Apple HomePod mini at $78.55/mth (U.P. $118.55/mth)
  • Comes with XGS-PON Optical Network Router + 2 units of TP-Link BE22000 WiFi 7 Router and an Apple HomePod mini
New users seem to get better offers.
https://www.singtel.com/personal/products-services/broadband/fibre-broadband-plans
https://www.singtel.com/personal/products-services/broadband/eform/5gbps-2yrbb-tv-bundle
All-in 5Gbps Broadband + all-new Singtel TV Bundle​
(Exclusively for new Broadband sign-ups and new TV only)
Here's what you will get with this bundle:
  • 12 months of Disney+ Premium on us (U.P. $15.98/mth), no contract
  • 12 months of Amazon Prime on us (U.P. $2.99/mth), no contract
  • 12 months of Viu Premium on us (U.P. $8.98/mth), no contract
  • 12 FREE months of Broadband Protect (U.P. $3/mth), no contract
  • Registration waiver (worth $54.50/mth)
  • NLT Service Activation Charge waiver (worth $61.04)
  • Weekday/Weekend Installation waiver (worth up to $147.71)
  • Home Line
  • FREE 4G Mobile Broadband (500MB)
Please select your preferred bundle:
2 FREE years of 5Gbps Enhanced (WiFi 6) Plan + Singtel TV Bundle at $46.76/mth (U.P. $153.88/mth)
Plan comes with:
  • FREE 2 years of 5Gbps Enhanced Plan bundled with 1 unit of Singtel WiFi 6 Mesh Extender
  • 1 x Singtel TV Local Languages Pack
  • 1 x Singtel TV Sports Pack
  • FREE 24 months Android Set-Top Box rental
2 FREE years of 5Gbps Enhanced Mesh (WiFi 6) Plan + Singtel TV Bundle at $54.40/mth (U.P. $164.07/mth)
Plan comes with:
  • FREE 2 years of 5Gbps Enhanced Plan bundled with 2 x Singtel WiFi 6 Mesh Extenders
2 FREE years of 5Gbps Enhanced (WiFi 7) Plan + Singtel TV Bundle at $63.56/mth (U.P. $187.48/mth)
Plan comes with:
  • FREE 2 years of 5Gbps Enhanced Plan bundled with 1 x TP-Link BE22000 WiFi 7 router
There is another offer link for recontract of 5Gbps plan.
https://www.singtel.com/personal/products-services/broadband/eform/recon-dm/fibre-5g
Singtel Fibre Broadband Plan​
  • Home Line
  • 12 months of Disney+ Premium subscription on us (U.P. $15.98/mth applies thereafter)
  • 12 months of Amazon Prime subscription on us (U.P. $2.99/mth applies thereafter)
  • 12 months of Viu Premium subscription on us (U.P. $7.98/mth applies thereafter)
  • 12 months of Broadband Protect subscription on us (U.P. $3/mth applies thereafter)
Select your preferred plan (24-month contract):
5Gbps Enhanced Mesh plan at $46.90/mth (U.P. $95.90/mth)
  • Comes with 1 unit of Singtel AX5400 WiFi 6 mesh router
5Gbps Mesh plan at $52.09/mth (U.P. $106.09/mth)
  • Comes with 2 units of Singtel AX5400 WiFi 6 devices
The forllowing Singtel 3Gbps offer is said to be for new users and targeted existing users only. If you are an existing users but not targeted (not receving the offer through SMS/Email/Post), you may still try to negotiate with Singtel to see if you can get the same offer or not.
Terms and conditions:
https://www.singtel.com/content/dam.../fibre-3gbps-enhanced-plan-btl-eform-tncs.pdf
This is probably the best deal from Singtel (cheaper than Singtel 1Gbps/2Gbps plan). But take note Singtel uses ONR and you may or may not be able to bridge the Singtel issued XGS-PON ONR (ZTE F8648P or Nokia XS-240X-A).
https://www.singtel.com/personal/products-services/broadband/eform/3gbps-enhanced-plan
Home line​
Registration fee waiver (worth $54.50)​
Singtel weekday/weekend router installation waiver (worth up to $147.71) - ONLINE EXCLUSIVE​
12 months of Broadband Protect (U.P. $3/mthapplies thereafter)​
12 months of Disney+ Premium (U.P. $15.98/mththereafter)​
6 months of Amazon Prime (U.P. $2.99/mth applies thereafter)​
3Gbps Enhanced (WiFi 6) Plan at $29.90/mth (U.P. $84.90/mth)
Comes with 1 unit of Singtel WiFi 6 device
Existing user 10Gbps recontract offer as of today 26-Nov-2024 --> not a good offer as the bundle Singtel mesh solution is lousy.
https://www.singtel.com/personal/products-services/broadband/eform/recon-dm/fibre-10g
All-in 10Gbps Mesh plan at $79/mth​
(24-mth contract)
  • Home Line
  • 12 FREE months of Disney+ Premium (U.P $15.98/mth applies thereafter)
  • 12 FREE months of Amazon Prime (U.P $2.99/mth applies thereafter)
  • 12 FREE months of Viu Premium (U.P $7.98/mth applies thereafter)
  • 12 FREE months of Broadband Protect (U.P $3/mth applies thereafter)
Please select your preferred Fibre Broadband Plan (24-month contract):
10Gbps Mesh Plan at $79/mth (U.P. $139/mth)
  • Comes with 2 units of Singtel AX5400 WiFi 6 Mesh devices
