Which wrench is better to use? To unscrew basin water tap
nez
Loosen can use any adjustable wrench that can fit the nut at max opening (mean is a small wrench)... U only need one or 2 half turn to loosen then can use hand twist all the way till the nut come off the thread
Yeah. I know what you mean.
It sound simple but when doing it is quite different.
I expect many cuss words from my mouth. :LOL:
nez
Not for this particular use case. It is my most used adjustable when working anywhere that doesn't require leverage. Silky smooth one hand adjustment.
Yes. I actually do have one of this in my tool box.
alex22
Is ok la, how often u do this anyway.
But the neck and shoulder will ache very much cos of weird angle.
I changed few tap at home, only thing i needed to call professional was whole basin replacement cos i dun have the appropriate drill eqt.
Well bbfa afterall.
Goot luck
XcoVar
Off main water supply and make sure faucet is in a "close" position before removing the flexible hose. By doing so, the water remains "locked" in the hose, therefore it won't flow out instantly. Next, position the hose into the pail and turn on the faucet to release rest of the water.
alex22
o_O
not even an expert in this
would rather let the plumber do the job :o
unless it's a straight forward task
Calling plumber about 80 minimum.
Can weigh the odds.
Maybe ts want self satisfaction?
I low ses no mixer tap all cold and 80 is like a month of caipng.
Tap also buy from taobao, free pipe
Justrade
This is the one I use at home
This is the correct one. Just need to get the correct size. All others are waste of time.
coyote
Am replacing my basin mixer water tap.
I see that there are 3 different types of wench available to use in tight places.
Those with experience can advise which wrench to buy?
No. 1, No. 2 or No. 3?
Thanks
My underside of the water tap.
It is a very tight space. The left side (white colour is the sink)
2 is better.
coyote
Those indeed are the best. Though have to remove the hose first before tightening or releasing. No. 2 however can tighten or releasing the nuts without disconnecting the hose and can be useful in certain circumstances.
I have both types.
ceestudent
When buy the tap, just replace the flexible hose. If don't want to replace, at least get the rubber gasket/o-ring.
The flex hose connection to the tap sometime can drip water when your rubber o-ring used up. Usually the tap come with flex hose,but need to check the length.
can buy better brand if you don't call plumber, use the plumber cost to get better quality. Rubine or rigel quite ok. Else get grohe if you heavy duty user.
alex22
Wah grohe.
Ikea i already stun...
Why no one suggest toto?
Rubine is canot buy. Vietnam hv better quality parts
Firstclass1188
Thanks
All no good, there is another one which looks like a steel pipe, the plastic one no. 2 is usable but flexes if you need extra tightening torque, the rest are awkward to use.
Read HWZ Forum Rules!
nez
Well bbfa afterall.
Goot luck
Thanks, I really be needing it
nez
Roger. Thanks
nez
Can weigh the odds.
I can spare the time, and I prefer to DIY whenever possible. Also to save money.
