Which wrench is better to use? To unscrew basin water tap
itangg12
Actually u need just a screw driver to loosen the 2 screw then unscrew the nut by hand :D
XcoVar
These rubber hose will hardened over time, say if lasted you 8 - 9 years, better get it changed. Mine burst in the washroom, luckily not the kitchen cabinet or else the wood will get water damage.
klim668
I agree this type looks easier. But unsure if the 2 water pipes can pass through
Yep, very likely it's not possible to get into the hole of a box spanner bcos the 2 nuts below at the end of the flexi hoses will get in the way....hmmm the 2 nuts below, nevermind.
The red tool in pic2 has an opening at the side where u can slip the pipes in sideway...hmmm. But come to think of it, the thickness of the hoses might be also too big. In this case, i think tool no.1 is your best choice liao.
KnyghtRyder
Hi to clarify, the 2 short water pipe I am referring to is the Hot & Cold water pipe/hose.
As for the water faucet nut, you know for a fact that it is not meant to be tighten but it acts as leverage for the 2 screws to be tighten to secure the faucet?
If that is what you are saying, then I need not require a specialize wrench as I can just use hand to unscrew the nut?
I do know for a fact.. the design is such that you tighten the screws to have even pressure. Whereas when you tighten it via a nut the pressure is eccentric. It also serves as a locking function.
nez
These rubber hose will hardened over time, say if lasted you 8 - 9 years, better get it changed. Mine burst in the washroom, luckily not the kitchen cabinet or else the cabinet will get water damage.
I see. Ok. Thanks for the warning
nez
:ROFLMAO:
Jokes aside, thanks for your advise
nez
Hmmmm ok. Would you know if the faucet comes in 2 parts? I am guessing one part connect to the nut and another for the screws?
Croiseur
Can use the adjustable wrench which is easily found in neighbourhood hardware shops
I also used this, a few months ago when I had to unscrew the bolt at the under side of the sink. It is not a smooth process though, as the space like you said is very tight you just have to keep trying
deemax
I bought no. 2 to change my kitchen faucet( hot and cold water tubes). The plastic body flexes when torque is applied and couldn't get the stubborn nut to loosen and turn. Bought the correct size box spanner for a few bucks and job is done easily.
nez
I just saw this video on the fixing of mixer faucet. Can also see theirs also have the same big nut with 2 screws. The tap comes in 1 piece. But it did not show whether the big nut need to be tighten by hand or wrench.
nez
Roger. Thanks.
I do have a small adjustable wrench with short handle, I shall see how.
nez
Yeah, that is what I am concern will happen.
Just to clarify, the big nut you need to use wrench? Cannot be loosen by hand?
To clarify, how do you use the box spanner to loosen the nut when the 2 water pipe/hose is sticking out?
I will see how.
Thanks
barbaricboon
Just buy the hex tube and try if can fit 2 pipes. Only less than $5. Fit through 1 pipe 1st then fit through the other 1. (Need to squeeze, and also depends on the sizing of the hex tube u bought).
Worse come to worse, just fit cold pipe, then blank off the hot pipe outlet. (The metal blank cap can buy from Mr DIY)
deemax
I will see how.
Thanks
Yes. It's for the big nut. Mine doesn't have the 2 long screws like yours. Basically, you really only need the wrench's help to overcome the force needed to "unlock" the nut. Thereafter, you can do it by hand.
nez
To clarify, you mention you bought box spanner, how do you use the box spanner to loosen the nut when the 2 water pipe/hose is sticking out?
