there is a steel bar like the red tool u showedProblem I think is due to tight places, this is not suitable.
There is basically no space for you to turn, not even partial turn.
Yep, very likely it's not possible to get into the hole of a box spanner bcos the 2 nuts below at the end of the flexi hoses will get in the way....hmmm the 2 nuts below, nevermind.I agree this type looks easier. But unsure if the 2 water pipes can pass through
I do know for a fact.. the design is such that you tighten the screws to have even pressure. Whereas when you tighten it via a nut the pressure is eccentric. It also serves as a locking function.Hi to clarify, the 2 short water pipe I am referring to is the Hot & Cold water pipe/hose.
As for the water faucet nut, you know for a fact that it is not meant to be tighten but it acts as leverage for the 2 screws to be tighten to secure the faucet?
If that is what you are saying, then I need not require a specialize wrench as I can just use hand to unscrew the nut?
I know as counter clockwise to loosen and clockwise to tightenAnd don't forget...
Lefty loosey, righty tighty..
You done it before?Actually u need just a screw driver to loosen the 2 screw then unscrew the nut by hand
I see. Ok. Thanks for the warningThese rubber hose will hardened over time, say if lasted you 8 - 9 years, better get it changed. Mine burst in the washroom, luckily not the kitchen cabinet or else the cabinet will get water damage.
The red tool in pic2 has an opening at the side where u can slip the pipes in sideway...hmmm. But come to think of it, the thickness of the hoses might be also too big. In this case, i think tool no.1 is your best choice liao.
Hmmmm ok. Would you know if the faucet comes in 2 parts? I am guessing one part connect to the nut and another for the screws?I do know for a fact.. the design is such that you tighten the screws to have even pressure. Whereas when you tighten it via a nut the pressure is eccentric. It also serves as a locking function.
I also used this, a few months ago when I had to unscrew the bolt at the under side of the sink. It is not a smooth process though, as the space like you said is very tight you just have to keep tryingCan use the adjustable wrench which is easily found in neighbourhood hardware shops
Roger. Thanks.I also used this, a few months ago when I had to unscrew the bolt at the under side of the sink. It is not a smooth process though, as the space like you said is very tight you just have to keep trying
Yeah, that is what I am concern will happen.I bought no. 2 to change my kitchen faucet( hot and cold water tubes). The plastic body flexes when torque is applied and couldn't get the stubborn nut to loosen and turn. Bought the correct size box spanner for a few bucks and job is done easily.
Just buy the hex tube and try if can fit 2 pipes. Only less than $5. Fit through 1 pipe 1st then fit through the other 1. (Need to squeeze, and also depends on the sizing of the hex tube u bought).I agree this type looks easier. But unsure if the 2 water pipes can pass through
Yes. It's for the big nut. Mine doesn't have the 2 long screws like yours. Basically, you really only need the wrench's help to overcome the force needed to "unlock" the nut. Thereafter, you can do it by hand.Yeah, that is what I am concern will happen.
Just to clarify, the big nut you need to use wrench? Cannot be loosen by hand?
I will see how.
Thanks
