- Jul 14, 2005
Don't need. It's like iphone. Auto activate when you switch on your phoneFor oppo warranty need to reg?
Don’t think so bahwhen buy?
Lol dont find reasons not to buy la.....Why so bias 33w for non-eu region...=(
How's the battery life so far? Though the os needs time to adapt and optimize based on usage
Fast Charge
80W SUPERVOOCTM 2.0, SUPERVOOCTM, VOOC 4.0, PD (9V/1.3A), EU: PPS (11V/5A), Non-EU: PPS (11V/3A)
50W AIRVOOC
This is pro or non-pro? SOT is great!
Ask yourself if google services is important for you. If yes, then better buy global romwill you all consider getting at Chn is you're here in Chn?
No eSIM and diff OS? Also got 256GB option of course.
Subjected to availability. If have, definitely can changeWah managed to hoot liao but black out of stock, went for Grey. Hope they have stocks of black for me to change
Bro, based on my experience, battery life definitely better than s24+This is pro or non-pro? SOT is great!
Esim a must for me.will you all consider getting at Chn is you're here in Chn?
For those who collected from DV, got check the phone on the spot or just take and go?
Very useful if going overseasEsim a must for me.
Non proThis is pro or non-pro? SOT is great!
aside from what others have mentioned about eSIM, using global ROM will be more convenient if you'll be using the phone outside of CN. I've used CN ColorOS and while I like some of things they offer (more granular permissions management, ability to uninstall a lot of the built in apps), it's a bit more of a hassle since for us who use apps outside of CN and installed from Playstore, will need to change settings to make sure they get immediate notifications, and it wont have things like nearby share, android auto, google location history.will you all consider getting at Chn is you're here in Chn?
