can use sim card verification too without appneed to download the app and reg to install the cert....
to me is working fine ...
but problem is smoker rather pay for a pack of cigarettes instead8 mobile $8 for $188GB. Cheaper than a pack of cigarettes.
Nowadays still need wireless@sg?????
Ya! That's right.I had it set up many many years ago liao. I think got 8 years or even more.
It will auto connect as wifi when you go to certain places which is annoying, you cannot disable it. So need to manually off it to connect back to your mobile data.
Then when you go library, their free wifi is this wireless SG. Sibei mafan to set up. They should just put username and password and let people connect right away.
But now I no need to use liao. 228GB mobile data.
I go library quite often. Sometimes library have bad connections, so wireless@sgx helps.I had it set up many many years ago liao. I think got 8 years or even more.
Office no wifi?Ya! That's right.
I also don't use it even for my office one.
I just set it up for testing after hearing so many people are having problem getting it connected.
You mean telco mobile reception not good at library ah? I haven’t tried yet. Seldom go library.I go library quite often. Sometimes library have bad connections, so wireless@sgx helps.
After a long time , I tried to connect through Simba network.. all opt etc went through.. but unable to connect..
Does this infrastructure still relevant? Wasting public money?
Got.Office no wifi?
Dun have to worry if use via vpn.I don use public free wifi locally and overseas.....cause U worry my HP kanna access . Even my sis who plays digital coins and has ewallet, she doesn use that too
Depends on location and number of users especially, it's decent here in CCAfter a long time , I tried to connect through Simba network.. all opt etc went through.. but unable to connect..
Still useable. Some hotspots doesn't work and unable to connect to the network.After a long time , I tried to connect through Simba network.. all opt etc went through.. but unable to connect..
