- Sep 16, 2018
If that's the case, would there be any other ONT pairing recco assuming Wifi7 is not a requirement?
The devices we use at home (iPhone 15, Macbook Air, Smart TV, Dell Latitude) does not support Wifi7 hence we wouldn't be able to fully maximise its usecase for EB10v/HB710 anyways.
Edit: After watching more videos and reading articles on Wifi7 - I do see the benefits of it even for devices that are not yet capable of Wifi7, and I assume TP-Link EB810v and HB710 combination is the most cost-effective pairing as of now?
If you need 10G capable WiFi 7 routers, then indeed TP-Link EB810v+HB710 is a very cost effective option as of now for Starhub users.
Some users opt to use 2.5G capable router to go with the Starhub 5Gbps special ONT offer at S$29.55 per month while waiting for better 10G capable WiFi 7 routers to drop price to a lower level. That is perfectly fine as well.
Some users will choose to go for better ones like Asus ROG GT-BE98 or ZenWiFi BQ16 as they do not mind paying more to be future proof.
All in all, there are different options, depending on budget. Different people will have differnt budget allocations. Often home networking gears may not be high on the list compared to a mobile phone. This is perfectly understandable. But then the expectation needs to be aligned with the budget.
