Oppo Find X8 Series
Sendai
Based on stock launcher, it only has red dot on the icon when there's a new message.
Hmm the problem is that I don't even have the red dot showing, whereas WhatsApp, etc do show the number badge on the app icon itself, so just wondering if there's issue on the launcher
This is home
doesn't seems like it protect the side of the phone
you mean the casing ?
ya noticed that .
wondering can use those
that are fully cover one or not .
saw tb have those full cover one
but don't know can use with the
power bank or not lor .
magnetic is convenient
but hor must buy the right casing
and if buy from oppo also expensive.
ahhe84
I had switched to x200 pro.. tired of looking for tempered glass..
Looking my x200 pro come with tg no problem
ZergRush
Yea x200 pro same quad curved display. And Vivo x200 pro are 50-50 boe or the inferior visionox display.
Whereas Oppo x8 pro are 100% boe screens
hstreamy
Hi guys I'm using find x8 pro here.. got any tempered glass to recommend which is friendly usage ? Current I'm using a normal screen protector but my casing Alway push up the edge with bubble.. very dulan..
Due to slight curve at sides, only this type can be used atm. Am currently using, quite good I must say....AR function can works as well...
【淘宝】大促价保 http://e.tb.cn/h.TfAbX1nmnS4sO6b?tk=lUgC3CpVYkL CZ0015 「适用OPPO findx8proAR抗反射保护膜AR护眼菲林光固膜findx7ultra手机膜降反射降反光增透膜findx6膜高清钢化」
点击链接直接打开 或者 淘宝搜索直接打开
ZergRush
No. I saw on douyin they took a pic of flower then initiate ai to ask which kind of flower is that. Or initiate the ai to reply a message or write notes.
When the ai initiates,the borders of the phone runs rgb
hstreamy
That's only available in china room ...not the the global variant.
ZergRush
the tempered glass for x800 pro i am using until now no problem swee swee...
Dont they all come with pre installed screen protector. Actually using corning glass should not need protector.
My old samsung a52s is corning glass 5 and no damage for 2 years without protector. And thats the older corning gorilla 5 glass
Gondon72
maybe you not like me that sometimes my phone can just accidentally hit myself and fly onto the floor with a big piak sound. :D
