Oppo Find X8 Series
Gondon72
Change another casing and lens protector.
Sendai
Hmm the problem is that I don't even have the red dot showing, whereas WhatsApp, etc do show the number badge on the app icon itself, so just wondering if there's issue on the launcher
I managed to understand the situation on why they badges icon won't show on some apps. If we set the badges settings to "number", not all the apps will show the numbers when messages in, but if we set to the original "dot" as notification, all the apps will display the red dot whenever theres an update.
This sounds either a bug or this feature is not really well polished for the stock launcher.
BenCJW
Hello, does anyone know what’s included in the box for the x8 non-pro?
I’m looking to buy from Mister Mobile as their price is good $1048
thanks so much!!!
BenCJW
if it's local set:
In the Box
Phone x 1
Charger x 1
USB Data Cable x 1
SIM Ejector Tool x 1
Quick Guide x 1
Safety Guide x 1
Protective Case x 1
Thank you! Hearsay some global versions don’t include charger
lorettatay
thanks so much!!!
Wasted. Last week shopee has $130 off. Non pro around $980.
Gondon72
actually do you all feel the sound quiet soft even when you max the volume during talking over the phone?
ahhe84
vibranze
Btw, anyone know if there's a photo gallery app that can sort or find photo based on orientation, i.e. vertical or landscape. Thanks.
