Please log in and verify your age to view this post. Why?
That's very true Bro chaiscool!Typical old bird noise. They will say abuse nsf also better
It makes a good walking stick. Also, it is better balanced without a loaded mag inserted. SAR21 is very front heavy.So moi enlisted on 2011...
During BMT and medic school, we use SAR21 to train...
Very good gun, short short so easy to move around, then got scope so very easy to shoot...
Some more charging handle by the side so easy to pull...
Then moi got posted to Air Force and we are forced to use M16 because we are considered rear units...
The M16 so long move around so mafan...
Then the iron sight so jialat so hard to shoot...
Charging handle also at the back which make it hard to pull...
But why so many old bird said M16 better? Is it nostalgia?![]()
I think the carbine is still used by armor.Got.. my unit had. Now I don't know anymore.
M16 run soc last time very pain. Back will have abrasion
Chiu also air force Bro Bardiel?![]()
Yeah sia Bro XCalintz!M16 iron sight confirms not as easy as the SAR21 scope. Day shooting is still okay. Night shooting is a lot more difficult with only a small highlight guide.
Moi thought SAR21 ish back heavy Bro DragonFire?It makes a good walking stick. Also, it is better balanced without a loaded mag inserted. SAR21 is very front heavy.
In the kind of action SG troops are likely to see tho, I think the SAR21 is the better conscript rifle.
Anybody can pick one up and plink off man sized targets at 100m with little training. That’s really important.
AR15 platform requires quite a bit more skill to use well, and the old rifles SAF has are a bit worn. We used to stuff twisted tissue between upper an lower receiver to stop the wiggles at range time.
I see Bro Bardiel...no. was in some service battalion
cos my era was the camou to pixlised era
so bmt sar train. go unit m16 train again =/
Whats M6 Bro Mark8888?I used M6 during NS. My son told me SAR21 is not for left handed folks because the dust cover is on the right side of the butt.. Both of us are left handed and our master eye is on the left.
Moi thought SAR21 ish back heavy Bro DragonFire?![]()
Tiagong ish higher Bro randyap...Would be curious to see SAF statistics for marksman before and after conversion to SAR21
That ish very true Bro randyap...Use M16 easier to rifle-butt the enemy during close combat.
That ish correct Bro st0rm5cap3...I used both before. Bobo shooter with M16 but marksman with SAR21. So there u have it. Sighting better, smaller so can hug tighter to steady each recoil.
