30s-50s chitchat club
Duc_mn
yes, that is why i use past tense "headed" they also import vietnam wives for past 20 years
past 2 year, thru common acquaintance met quite a few of vietnamese masters / PHD scholarship holders doing their qualification. some of them are fully sponser by pharma in vietnam. some are under university.
pray share when it happens, any plans for Mount Blanc?
Did Tour du Mont Blanc this year
Mr.Kopi
this mont blanc?
LingTan98
I am planning to install a Xiaomi CCTV outside one of my units, but there are no power sockets and my idea is to connect the CCTV to a powerbank and charge the powerbank using solar panels in the day. Powerbank will be hidden inside a compartment near the roof close to the CCTV. Do anyone have any suggestions?
RyanJ
Get Amazon owned Ring or Google owned Nest. Get an electrician and wire them up and forget about low battery, pay a subscription. It is the path of least resistance and saves headaches.
Also the communication lag if you are talking via the cctv/doorbell is minimal because of fast servers.
Their Ai logs faces and videos in case you have some issues and need to retrieve footages / unregistered faces.
The other options require either too much technical hands-on or fiddling or monitoring.
lemonzil
The one with the university? My cousin works there as an associate consultant 🤣 she told me that her mentor is thinking to move to private practice soon.
Is a common thing I hear. Nurses / doctors always talk about moving to private instns or practice
highsulphur
I stopped reading at "one of my units".....
albert.wesker
Do you install CCTV in your living room when U rent out your room(s)?
I am going to have a lot of comics and CDs in my place but I don't think people will steal these stuff generally 🤔
