My LDL also jumped alot in 6 months.
I did yearly ultrasound, the last check says that they observed more fatty liver.
I don't drink, so it's non-alcoholic fatty liver.
So I'm wondering is the fatty liver causing it to haywire and drive up a lot of cholesterol.
Those with high cholesterol may want to check if they have fatty liver.
Since 80% of cholesterol is produced by the body than diet.
I'm 62kg 173cm.
I read that reducing weight 5 to 10% is the key, but that will put me to 56kg to 59kg, very thin man,
Don't see how else to effectively reduce that.
If reducing the fatty liver is indeed the key, then isn't the target is to fast and reduce weight, more than the diet itself?
Diet can encompass a lot of things, including fasting
Sometimes, it's what we eat that is also important
One of the biggest culprits behind NAFLD is fructose - yes, that means eating a lot of fruits is bad for our liver
Another culprit is highly processed food which usually contain a lot of HCFS or high fructose corn syrup - they are a lot cheaper than normal sugar and highly addictive
Last but not least, some consider vegetable cooking oils to be another cause - these contain a lot of O6, highly unstable and can cause inflammation in our bodies
More inflammation means our bodies (liver) need to produce more cholesterol, especially LDLs to help repair itself
Fasting is seen as a part of our diet as well - before our cushy lifestyle, humans don't eat all day long and definitely not on cheese burgers at 2am whenever the hunger pang strikes
Hence, adopting a type of intermittent fasting i.e. eating within a 4 or 8 hour window gives our bodies time to digest, use up the energy and more importantly, the excess glucose in our liver
