[OFFICIAL] Taiwan Guide and Taiwan related matters - Part 9
twosix
thanks for the info, used to take 1819 to fro Taipei and the airport, but now use the metro instead.
Yup with the metro 36min only to tms. Was thinking of taking the 1819 due to retro feel but now that it is relocating to qsquare which i find is further away, gonna take metro this time again. Haha.
pohu
Do you reconmand bring cash? will be there for 1 week . im planning to withdraw from there using Trust card or Wise card or even Youtrip card.
Maybe keep some spare cash in your wallet, as what if you can't find a ATM when need to?
pohu
QSquare - I remember the berth of those bus companies are located on different levels of the building
Laneige
Example Starlux to MY is using A321neo but SG is using A350.
Airasia AK and Batik OD is using A320 and B737 whereby Scoot using B787 for taiwan
Airasia D7 is A330
How is A321neo vs 787-8 under scoot?
which one bigger more stable?
Laneige
Midnight flights r usually the smaller plane. Sometime can feel roller coaster ride. Haha.
har nor
i dont want. thats why i need to go for bigger one....
quite surprised seem liked SQ to n fro is cheaper than SQ,Scoot
anyone knows top up to 30kg for SQ is possible or not? their website v cui. Thanks
ApeTruelove
har nor
If buy from SQ web, make sure you see is from SQ not operated by scoot or Eva air.
Choose standard or flexi should be 30kg
calkel20
har nor
Scoot nowadays may not be cheap
Did you check eva or CI?
rrr2015
250 without luggage? Depending on traveling dates, China airlines or Starlux about 400.
scoot of coz without luggage but if add one check-in should around $300+. usually i travel with cabin luggage so check-in luggage allowance is wasted on me, also don't like airline food. more important is the plane & timing
