- Sep 16, 2018
hi, m1 1gbps @ $40 ending liao.. better to recontract to their 1/2.5gbps plan and included be230? currently using 2 zenwifi CT8, current hardware will still work with new plan right? TIA
If you want to stay with M1, you may have to go with the recontract with 2.5Gbps plan to save a bit of money.
https://www.m1.com.sg/home-broadband
M1 1Gbps recontract is at S$40.65 per month, new sign-up is at S$35.90 per month.
M1 2.5Gbps recontract is at S$39.90 per month, cheaper than M1 1Gbps recontract.
Your ZenWiFi CT8 can still be used but not recommended since Asus has EOLed the product and no longer provdide security updates. So it becomes a security risk. Last FW update was on 26-July-2022.
https://www.asus.com/event/network/eol-product/
https://www.asus.com/sg/supportonly/asus zenwifi ac (ct8)/helpdesk_bios/
If M1 6Gbps plan is available in your area, it may be a better option to get the 6Gbps plan at S$59.90 per month with a pair of ZenWiFi BT10 (triband WiFi 7 router, BE18000, dual 10G ports) and then sell one or two units to get much lower effective pricing. It is a better router than Archer BE230 (dual band BE3600, dual 2.5G ports).
M1 6Gbps with a pair of ZenWiFi BT10 at S$59.90 per month:
Selling one unit of BT10 at S$400 --> effective price of M1 6Gbps with one BT10 at S$43.23 per month.
Selling two units of BT10 at S$800 total --> effective price at S$26.57 for no-frills 6Gbps plan.
You can also read the first page of this thread, if you want to consider other ISPs.
