Need, unfortunately … from AC through AX, with primary node at DB, the load bearing walls between this corner of my home to my master bedroom at the 45-deg opposite corner, I get no 5G and 2.4G is spotty. Doubt the problem goes away with Wifi 7.Can work but you may not need the 710 router in the Master bedroom.
If so, all the discussion on the 10G router/mesh/switch no meaning for me anymore
