I got my BT10 twin pack 27 hours after the selected slot, some more the delivery guy got the cheek to ask me to rate him 9 or 10The delivery guy MIA! Ccb
Simba being available has nothing to do with M1 being available. The upgrade that is required is by M1. Did you manage to get the speed after the upgrade?
Speed should be there. I speedtest just now from my PC, maxed out at 2.5gbps due to my lan card only support 2.5I would have assumed they shared the same backend infrastructure (from OpenNet or Netlink trust), guess I'm wrong.
Not sure if the speed is there cos they will only install the ONT on Tues, will update the speed after install.
Didn't receive any email regarding the 6gbps recontract offer. Hope to receive it too
Is this offer considered one of the best now?
I chose BT10 cos of the small form factor (can hide inside my slim TV console) and also cos my FTP is at one corner so need twin pack to cover my 4-bedroom unit. The IoT devices initially have difficulty connecting to the IoT network but it was resolved via manual setup to create a separate 2.4Ghz band and combining only 5Ghz & 6Ghz in the main network. The BT10 does not seem to work well with older routers so additional nodes if required should preferably be BT10 too.If money is not an issue, better to choose BT10 over BE805? Whats the diff?
hi, older routers from ASUS?I chose BT10 cos of the small form factor (can hide inside my slim TV console) and also cos my FTP is at one corner so need twin pack to cover my 4-bedroom unit. The IoT devices initially have difficulty connecting to the IoT network but it was resolved via manual setup to create a separate 2.4Ghz band and combining only 5Ghz & 6Ghz in the main network. The BT10 does not seem to work well with older routers so additional nodes if required should preferably be BT10 too.
Found this info from TP-Link SGDo we need to register the M1 given TP-Link Archer BE805 for the 3 years warranty coverage?
What’s the go-to method for linking up the new multi-gigabit plans to SFP+ firewalls? Currently have a UDM-Pro and looking at the 6/10Gbps plans.
Current thought is to use a newer <=2W SFP+ to RJ45 connector from 10Gtek (ASF-10G-T80) but I’m not sure how the link negotiation will work out as it’s >5 but <10Gbps
I am now having about 4 ASUS routers in my Aimesh, planning to replace 2 of them with this twin pack BT10.
does BT10 not work well with older ASUS routers?
how old is old? and what exactly not working well?![]()
I have Asus AX3000, AX82U & AX Mini. From my testing, the backhaul connection using 5Ghz band is not that great. The client devices only connects to BT10 even if the wifi 6 routers are much nearer to the device.hi, older routers from ASUS?
Plan - HomePac 10Gbps Fibre broadband - 24 mths
$50.90/mth 24mth 10Gbps Subscription Discount - $13 off for 24 months
$50.90/mth
(U.P $135/mth)
Router
ASUS ZenWiFi BT10 (Pack of 2)
FREE
(U.P $22.09/mth)
Is this a good deal? $50.90/mth for 10GPS and free
| Theoretical Speed | Typical Speed Range* |
| 1Gbps | 931.4 – 941.0Mbps |
| 2.5Gbps | 1938.1 – 2096.4Mbps |
| 3Gbps | 2285.7 – 2579.7Mbps |
| 6Gbps | 2952.7 – 5714.1Mbps |
| 10Gbps | 3014.1 – 8234.5Mbps |
hi this plan is $32.90 promo price for 6Gbps. +$12 for Asus BT10
= $44.90
Quick question, is there a need to top up $12 extra for BT10?
TP-Link Be805 not good enough for normal daily use?
