- Sep 16, 2018
is the 10gbs plan any good? if you change the link for the 5gbs plan from fibre-5g to fibre-10g
If you are willing to pay, just go ahead. Take note the HB611-SGST given can only support 2.5Gbps.
https://www.tp-link.com/sg/service-provider/wifi-router/hb611-sgst/#specifications
To me it is not worth to pay extra for 10Gbps as it is only slightly higher than 5Gbps, due to the fact that all ISPs are using XGS-PON technology and the speed will be limited to 8.2x Gbps.
Reference: Singtel typical speed.
https://www.singtel.com/personal/support/broadband/typical-download-speeds
Typical local and international download speeds
The following is based on more than 200 measured readings for each Fibre Broadband plan across peak and off-peak hours. It is validated from October to December 2024.Peak hours are generally from 7pm - 1am, while off-peak hours are generally from 1am - 7pm.
| Fibre Broadband Plan | Typical Local Download Speed for Wired Connection* | Typical Local Upload Speed for Wired Connection* | Typical International Download Speed for Wired Connection* |
| 1Gbps & Unlimited Fibre Plan | 925.95 - 927.01Mbps | 921.24 - 922.15Mbps | 716.53 - 806.62Mbps |
| 2Gbps Fibre Plan* | 1810.37 - 1846.10Mbps | 1055.97 - 1068.49Mbps | 1364.41 - 1714.38Mbps |
| 3Gbps Fibre Plan | 2479.59 - 2768.89Mbps | 2491.40 - 2792.90Mbps | 1602.35 - 2346.32Mbps |
| 5Gbps Fibre Plan | 4611.37 - 4665.38Mbps | 4615.71 - 4652.32Mbps | 3469.04 - 4152.54Mbps |
| 10Gbps Fibre Plan | 7470.99 - 8014.25Mbps | 7765.43 - 7860.68Mbps | 4061.71 - 4231.52Mbps |
*The typical download speed range is computed to reflect that, at least 90% of the time, a user should experience the lower bound speed or higher.
^Download speeds for 2Gbps Fibre Plan reflects an aggregated speed of 2 speedtest readings done simultaneously on 2 client devices.
