johnsonheng
- Aug 1, 2002
If I ask other people to remote to my pc and configurebthe settings for me. Will it settle the issue
What model switch did you get? Got potos? If it is a dumb switch you should not need anything special config.If I ask other people to remote to my pc and configurebthe settings for me. Will it settle the issue
SynologyWhat brand nas? Synology? Or qnap?
Simi is natconfirm switch? Because switch is just multiple ports. If not switch, maybe need to configure NAT again?
If router never assign ipgo in ur router page see if ur router got give it an ip address. then u connect from there
Got liao.Just sign up for cloud storage services
Clean, easy, fast
It a cheap switch. Only has many ports.What model switch did you get? Got potos? If it is a dumb switch you should not need anything special config.
If it is a used enterprise switch, you may need to factory reset it.
If it is a cloud managed switch, you may need a license/subscription for it.
Cannot find. Tried many timeYou got cheated there, don't need to buy the switch.
If your router/internet works fine, phone can access, just connect NAS to router (I suppose this was your original setup).
Chances is, the NAS restart took on a new IP (DHCP). Use Synology Assistant to find the NAS (for Synology).
