Thoma5
- Oct 16, 2006
i heard if dun use those specially detergent for robot will spoilt...but if use 2 month and no problem shld b ok bahMaybe 2 months? You mean will have problems?
Which one? The funan side always crowded and can see from the counter got tons of repaired or pending repair stuff.Xiaomi service centre in SG is amazing and very few people there. Meaning their products seldom spoiled within warranty period.
I check on internet. There is only one service centre in Singapore and it is not in Funan.Which one? The funan side always crowded and can see from the counter got tons of repaired or pending repair stuff.
Ah paisay I thinking about the usual Xiaomi not vacuum it's the IMM one , hopefully don't get to go thereI check on internet. There is only one service centre in Singapore and it is not in Funan.
At lavenderAh paisay I thinking about the usual Xiaomi not vacuum it's the IMM one , hopefully don't get to go there
Because no blades that will get blunted or blade slots that could clogged with dirt, and
Hey there! That all-encompassing dust bag is such thoughtful design. What was your last robot? Did the purchase came with a UK type G power plug? Any form of warranty?Because no blades that will get blunted or blade slots that could clogged with dirt, and
plus side brushes also entanglement free design,
plus the dust compartment is bigger and does not consolidate into the station so I no need to clean the tunnel,
plus the station has drying and compacting function for the dust compartment,
plus the robot has no water tank so no need to worry about clogging or leak (which happened with my last robot, so should be able to use any detergent so long as no particulate inside it
plus the navigation and mapping AI seems really good in the comparison vids I saw,
plus the price was good and the shop offer free shipping to SG so it was only around $750 total for their latest model.
As compared to the older model J4 which was cheaper but side brush not entanglement free design, no drying and compacting of dust compartment, and less suction power and mopping pressure. Or their top end model 001s which is slightly more powerful with side brush but main advantage is that it has AI object recognition and voice recognition, but I didn't think I needed it.
Drawbacks is cannot use app, cannot set no mop zones, so it relies on the initial mapping and default settings only. If change layout then have to tell it to remap, if want it to not clean a room today, then gotta close the room door.
Last robot was a Hobot made by 波妞,they are more famous for making window cleaning robots, came with china power plug, this vacuum mopping robot was their first and last gen, and also why I prefer the Narwhal design, eliminates failure points, more failsafe design. But the Hobot station was just for charging, and it was so annoying having to clean the pads and empty the tiny dust tray everytime. Before that was Samsung early gen, same problem plus even more disgusting hair entanglement.Hey there! That all-encompassing dust bag is such thoughtful design. What was your last robot? Did the purchase came with a UK type G power plug? Any form of warranty?
Inability to use the app is a huge drawback. So you're just letting the robovac do its thing? No notification, relying on audio and visual cues to track job progress? Can't adjust settings such as the cleaning sequence, "Mop after Vac", schedule cleanup or create shortcut?
Nevertheless as long as the robot meets the user's needs, it's a good bot.Have a good night!
What robot do you have?Why you all buy so expensive robot? My $300+ robot just clean my house until so clean
I concur. Been to xiaomi funan svc ctr, had no queue.Xiaomi service centre in SG is amazing and very few people there. Meaning their products seldom spoiled within warranty period.
XM mop pro 2What robot do you have?
Including all incentive programs, I paid ~$450 for a Dreame L20 Ultra, a Tricut brush and a brush cover. I am elated with these purchases.
I also think don need to spent over 1 k on a vaccum machine. Anything below $500 should be able to do a gd jobWhy you all buy so expensive robot? My $300+ robot just clean my house until so clean
My robot vaccum after 2 years plus, the battery still going strong. I only replace the mop cloth so far.I also think don need to spent over 1 k on a vaccum machine. Anything below $500 should be able to do a gd job
Just put the detergent on the cloth before starting the moppingi heard if dun use those specially detergent for robot will spoilt...but if use 2 month and no problem shld b ok bah
The roller and the dust in the inner wheel compartment must be cleaned after each usage also.It's more about how much maintenance you can tolerate doing for the robot. Like emptying bin, cleaning mop and side brushes, refilling bucket and draining waste water,
