Oppo Find N5
Waiiii
Just to clarify the issue is not for MS Teams video call. the issue is for the chat and teams/ group chat. the keyboard will come up but you won't be able to see what you type. I can do fold and unfold action or back gesture a few times as a workaround but it is annoying. It is really a bug. Other apps are ok. so far in my case is MS Teams. Sadly I need to use MS Teams for work, a lot of chat sessions.
Try this within MS Teams when unfolded. Press Search button, type your colleague name, and click his/her name afterwards. his previous chat history will show up then try to type. the keyboard afterwards got stucked, you won't be able to type. The same with group chat too.
Read HWZ Forum Rules!
it is a bug , i am also facing this issue on N3. have to hit the "back" key in the convo. then select that convo again then the keyboard and can preview what you typing also.
gnownairb
This is a really stupid question, but anyone had trouble removing the provided magnet case after putting it on? The phone is so thin, I'm a little scared that using too much force will break it lol
Mankul
I cannot charge the Find N5 using OnePlus red cables...
I can use the N5 provided cables and charge with OnePlus 80W charges...
What is so specific about N5 charging cable?
nuscape
start preying from bottom right corner and work towards the USB port. it is difficult but that method works for me. I couldn't do it if starting from the top camera side.
Mankul
It is not even slow charging. Find N5 cannot even detect the charger when connecting using OnePlus red cables....
nuscape
oh no. it has been happening since N3 ? yes. you are correct. I had to hit back a few time in the convo then it will work, but not all chats. The method that will always work is to fold it and unfold it again then the keyboard will work in unfolded mode. If you select a different convo then you have to repeat the folding/ unfolding.
does this mean either Microsoft, GBoard or Oppo never realise this stupid bug and get it fixed until the next handset generation (since N3 and N5?)
gnownairb
Thanks, I'll try that later. It's really clamped on there
SomeH0w
If Amaze card previously added to your old phone / watch, probably exceeding the limits, just try to contact Amaze. I assume it should be the same as bank. Sometime they assume that is fraud or malicious activity hence they blocked the adding approach.
You are right - contacted. But the customer service told me to try again, 30 days later.
30 days
onceheaven
I take the case on off in off because i was trying with my metal plate for the magnetic car mount. I start by unfolding the phone, unhinge the "hook" on the corner nearest the top hinge. Once u push it a little and it shows the phone frame, its ez from there on
rebornsoul
Shouldnt have this kind of issue, I used quite a few types of cables and chargers at home and in office, all worked on the phone.
Just that it will only be normal charging or fast charging if it's not an Oppo charger. Never encountered any cables that wouldn't even charge the phone.
disr87
Sadly this kinda niche issue sometimes just no one will realise. Haha one thing on n3 is split screen in carousell cannot click the search bar. YouTube revanced cannot click the small video in bottom right corner (when revanced is on the right, when on the left can) for both n3 and Samsung.
nuscape
Is this qui
this device is being marketed as a productivity tool. it is weird that never been tested with Microsoft apps such as Teams, over 2 generations some more? it is not a bug that you would expect to see in a premium product line.
1982-1994
If the photo has text, it cannot be highlighted in the gallery? Like on iPhone
1982-1994
Battery life since around 1220am ,from 90%
Mix of browsing and streaming 2 episodes of HK drama ,every % average out 9mins of SOT, very good
