This is normal only leh ... I hit almost 4.2Gbps on Xiaomi 15 liao ... OP13 easily 4Gbps. This one smell no smoke ...
@Fellowes For your ref, S25 Ultra ...
Must be ur asus routerThis is normal only leh ... I hit almost 4.2Gbps on Xiaomi 15 liao ... OP13 easily 4Gbps. This one smell no smoke ...
I thought all these devices are using sd8 elite chip. Should have same WiFi capabilities.This is normal only leh ... I hit almost 4.2Gbps on Xiaomi 15 liao ... OP13 easily 4Gbps. This one smell no smoke ...
ASUS tried, TP-Link also tried.Must be ur asus router![]()
Samsung there’s some wifi saving setting enabled by the OS, you can try. You speed test a few times the speed will gradually get faster and faster, like need to warm up. Xiaomi is never pull hand brake, it goes all the way to max. OnePlus around 4.xGbps.I thought all these devices are using sd8 elite chip. Should have same WiFi capabilities.
Unless Samsung is limiting the speed which is unbelievable.
Not using any. Samsung already have the default cleaning widget that you can use that although cleaning apps are not necessary 99.9% of the time.What cleaning apps do your use ? I using CC Cleaner but need activate through "Accessibility" section every time I need.
i used to used sdmaid also alot restrictions since android 15. I have stop using now on samsung phonesWhat cleaning apps do your use ? I using CC Cleaner but need activate through "Accessibility" section every time I need.
Thanks for that. I missed on the default cleaning widget. Except cache files have to do it individually.Not using any. Samsung already have the default cleaning widget that you can use that although cleaning apps are not necessary 99.9% of the time.
yeah , i'm just using the samsung cleaning app. it finds duplicated files and large files as well. not bad.Not using any. Samsung already have the default cleaning widget that you can use that although cleaning apps are not necessary 99.9% of the time.
yeah i notice my fold5 also detect much faster .Had issues with Google pay also. Reader cannot detect even when Google wallet app is opened. Switched to Samsung pay now better. Think it's a one UI 7 issue.
my files -> manage storage , then it will have options to show duplicated files , recycle bin , large files , review old files ( whether u want to delete or not) unused apps etc etcIs it the one in the setting under "Device care" ?
u can click on the arrows to see what files in each category n delete also.
