Samsung Galaxy S25, Edge! FE! Ultra! & Accessories ..
What do you think is the nicest color S25 series?
  • Total voters
    203
robie_aibo
If I were you, I will try to find oem rings, or just buy another set of the lens protector and put on a case that does not cover the cameras.
$200 for those glued on rings isn't worth it.
Need to be careful. I almost did the same thing as you. You have to make sure when you remove the ring, you "lever" against the outer camera protector. I suspect what you did was your screwdriver went a bit too deep and end up "levering" up against the inner camera ring
I guess so... my wife's set I will leave it as it is as she doesn't want her phone to be hospitalized. Now all phones going to service crntres have to be reset even though Samsung has this repair maintenance feature. I was told something happened that's why they want all customers to backup and reset their phones.
trenzterra
Now I don't stick the lens protector instead I stick the glass protector just for the lens.
So far I don't find those glass protector alone to give good image quality. Actually I think can go naked one. My s23u went naked for camera 1.5 years no scratches
robie_aibo
Maybe I will leave them nake. Haiz, this year Samsung cuts cost; used glue to glue the rings to the lens. S24 built quality was better than S25
gapboy
https://www.androidauthority.com/ge...MmT_2pYEd_UqO2GUEE_aem_qRf8mxuIhNp3EUxRoHhaIw
Your Galaxy S25 lock screen is getting a big Gemini Live upgrade
albel81
Is this a known issue? I put my SIM in SIM SLOT 1 (SIM 1 is engraved on tray) and is displayed as SIM2 in SIM Manager. I understand you can edit the name in SIM Manager but such a silly mistake.
Is this the 2nd SIM u inserted? I think something changed. From my usage, seems like the name no longer means which Slot.
So if u insert 3 different SIMs, then u can have SIM1, SIM2, SIM3.
Basically, name of the SIM, regardless of which slot u put in. At first, I am also confused. But this is what I understand after some experiment.
Milo Van
Is there a way to enable the screen to light up when we receive notification like Whatsapp msg?
Now can only hear sound notification but the screen remains black, need double tap to see from lockscreen.
Have already enabled every applicable notification setting but dont seem to work.
gapboy
edge lightning + from good lock or use aodnotify
DigDub
Can use glimpse notifications app.
Galaxy Commander
Featured Sponsor
Galaxy Commander
Featured Sponsor
Hello!
You can purchase Samsung Care+ via this page within 60 days of the purchase of your Galaxy device https://rg2.samsungcareplus.com/sg#/
Samsung Care+ is tied to your IMEI and Samsung account. So it’s best to assign a Samsung account to the device, or sign up for a new one if your family member doesn’t have one
eq2addict
there is a setting in goodlock where i can get a rainbow effect along the edge of my screen. quite noticable.
