Blueberrytea
- Dec 10, 2017
Any ways to increase sensitivity on one handed operation for good lock ? Very unresponsive on mine
Can increase the touch width in its settings tryAny ways to increase sensitivity on one handed operation for good lock ? Very unresponsive on mine
Yeah now in max liao try try...I feel kinda slowCan increase the touch width in its settings try
I didn't have it both in my s23u and s25u even after updatesYeah. it's also on our devices. Not sure when it auto installed. I deleted it without any issues.
I wiped the dalvik cache to solve some overheating issue maybe can try on this see how it goesYeah now in max liao try try...I feel kinda slow
Try swiping slower instead of microsecond speed lehAlso wipe b4![]()
Lol phone cannot keep up with me I need slow down to accommodate ?Try swiping slower instead of microsecond speed leh
I have both! Tell me what you want to know?Contemplating between S25U 512GB at around $1.4k or OP13 512GB at $1k
The OP13 seems to have way better value but the S25U does seem to have a certain X-factor.
Can buy care plus from phone settings. Tied to your Samsung account.Regarding sc+:
If buy from other stores like shopee or telco,
How do i buy sc+?
Is sc+ tied to my samsung account?
Does that mean i need to log in my samsung account on my family member phone to get sc+ for his phone?
Not sure when it auto installed. I removed it a few days ago.I didn't have it both in my s23u and s25u even after updates![]()
What brand you use? When you removed it, the leverage did you apply too deep such that it lift the original lens ring too?Just to share.
I put on the lens protective covers and when I removed them, the original lens rings also got pulled out. During the removal of the protective covers, I scratched the frame. Just sent 2 units to replace the back plate and titanium frame which cost me $200 each.
I bought from Taobao and Shopee. Think no brand... yes, I pressed hard so that the ring covers the original ring. The service centre advised me not to use these protective lens cover as they might pull out the original rings. Jerry did his review and was confirmed this year Samsung uses glue to stick the rings. Initially I thought the technician will just stick back the rings; in the end I have to pay for the entire back cover.What brand you use? When you removed it, the leverage did you apply too deep such that it lift the original lens ring too?
Shag.. how did you remove the ring in the first place? You slot something underneath and then pull up?I bought from Taobao and Shopee. Think no brand... yes, I pressed hard so that the ring covers the original ring. The service centre advised me not to use these protective lens cover as they might pull out the original rings. Jerry did his review and was confirmed this year Samsung uses glue to stick the rings. Initially I thought the technician will just stick back the rings; in the end I have to pay for the entire back cover.
Yes, used a thin flatbed screw to slowly remove the rings. Never did I realised that the original ring stuck firmly to the protective ring.... felt sianz seeing naked lens....Shag.. how did you remove the ring in the first place? You slot something underneath and then pull up?
Need to be careful. I almost did the same thing as you. You have to make sure when you remove the ring, you "lever" against the outer camera protector. I suspect what you did was your screwdriver went a bit too deep and end up "levering" up against the inner camera ringYes, used a thin flatbed screw to slowly remove the rings. Never did I realised that the original ring stuck firmly to the protective ring.... felt sianz seeing naked lens....
Lucky it took around 2 days for the spare parts to arrive the service centre.
If I were you, I will try to find oem rings, or just buy another set of the lens protector and put on a case that does not cover the cameras.Yes, used a thin flatbed screw to slowly remove the rings. Never did I realised that the original ring stuck firmly to the protective ring.... felt sianz seeing naked lens....
Now I don't stick the lens protector instead I stick the glass protector just for the lens.If I were you, I will try to find oem rings, or just buy another set of the lens protector and put on a case that does not cover the cameras.
$200 for those glued on rings isn't worth it.
