SingTel 3Gbps, 5Gbps & 10 Gbps Enhanced
cyberet
They will either keep the Singtel ONT or issue a new Singtel ONR for your Singtel digital voice service. This is the same for those who cancel their Singtel Fibre internet service but keep their Singtel TV service.
That means it will occupy one Fibre Terminal Port.
one fibre port for just a digital line. its good value, because ST would probably be paying out more to netlink trust than the digital line subscription 🤣
nabil996
The bad thing is my auntie used the digital line she face issues like example she call our home line something the line keep disconnect. Even when i call tech support via phoneline and they are like in shock when they ask me the phone is plug in via my ONT i said no.
MrConfused
Singtel just installed the ZTE ONR as part of the 5gbps plan. After installing it, my Asus XD6 router (used to be connected to ONT) and remaining XD6 AP didn't work after that. Now, after changing the main XD 6 router to AP mode and it still couldn't work (unable to get assigned an IP address). Does anyone know what should I configure in order to get it to work again?
nabil996
Have you change ip address before that ONR? default is 192.168.1.1
You can also change to Singtel Analog Line of you prefer that.
https://www.singtel.com/personal/products-services/more/telephony-services/home-line
SUBSCRIPTION AND SETUP CHARGES
Subscription charge for 3 months$29.98
One-time activation charge$54.50
New wiring for first 50 metres$54.50
CALL CHARGES
Monday - Friday (9am - 7pm)$0.0087 per 30-second block
Monday - Friday (7pm to 9am)$0.0087 per 60-second block
Saturday, Sunday and Public Holidays (whole day)$0.0087 per 60-second block
Not so sure if NLT charges SingTel the same amount or not in this case.
For debundle, NLT changes of S$61.04 should not be applicable. Hopefully ONT / ONR charges will not be applicable as well. Need to confirm with SingTel.
What are the charges for Singtel Home Digital Line?​
Call 1609 or visit any Singtel Shop to sign up.
Home Digital Line Only ^Singtel Broadband Customers #
Contract Term6 monthsNot applicable
Monthly Subscription$10.00Free
NetLink Trust Service Activation Charge$61.04Not applicable
ONT / Router one-time charge$109.00Not applicable
ONT / Router installation fee$54.50Not applicable
^ Customers who have standalone services with Singtel will need to subscribe to Home Digital Line with the stated charges.
# Customers who subscribed for Fibre Home Bundle and Fibre Entertainment Bundle will enjoy Home Digital Line as a complimentary service.
Note: All prices are inclusive of prevailing GST.
Factory reset the main Asus ZenWiFi XD6 and go through the setup steps one more time and choose AP mode.
Later you can go to SingTel ONR webpage 192.168.1.254 to look for the IP address of your main XD6 (192.168.1.x). From there you can go to the Web UI of the main XD6. Factory reset the second XD6. Set up AImesh from the main XD6 Web GUI.
nabil996
I thought ST have almost 25% of the company
nabil996
CALL CHARGES
Is there any difference between Digital vs Analog line?
MrConfused
next best thing is are u using mac or windows?
used ipconfig
I'm using Windows. @xiaofan if I want to use the Asus XD6 in router mode (running together with ONR without bridging), will it be the same steps as well?
nabil996
Press window and s then type CMD then type ipconfig see what is ur default gateway then login to that ip address
Similar steps.
Factory reset the main Asus ZenWiFi XD6 and go through the setup again. Choose router mode and DHCP. DO NOT use any special SingTel VLAN profile (only for Singtel ONT users).
Factory reset the second XD6. Then go to main XD6 web GUI at 192.168.50.1, and add second XD6 as AImesh mesh node.
limck
Is there any different in quality? No power as in PoE?
analog copper phone lines have 50V running though them if I remembered correctly. quality depends on how good is the copper lines between your unit till the singtel exchange. after so many decades should have some degradation but should be still ok.
for private estates, there was an exercise sometime ago to decommission all the copper lines but i think HDB not affected
cyberet
damn, should have known ST's modus operandi 🤣
emeritus
Yes, Archer BE550 Pro is good enough but may not be cost effective.
Cheaper one can be the Archer BE230 (dual 2.5G ports, dual band WiFi 7 BE3600, no 6GHz band) at about S$90 BNIB (or less now), dumped by M1 users.
Depending on the price you get for the Archer BE550 Pro, it is probably cheaper to get Archer BE805 (dual 10G ports, triband WiFi 7 BE19000) at about S$300 BNIB (or less now), dumped by M1 users.
Hi xiaofan, I assume be 805 is consumer retail unit and I can just buy from carousel ( dumped by M1) users and use it on my Singtel 3gbps right?
