deepblue_82
Manage to snag 9070xt. Now just need the parts to built around this card. Would need gurus to help see if this is okay.
CPU+Mobo: ASUS TUF Gaming B650M-E WIFI or MSI B650M Gaming Plus Wifi + Ryzen 7600 (not sure which board is better) - $413/$423
Ram: Team T-Force Delta CL30 6000MHz 32gb -$150
PSU: Xpg Core Reactor II 850W -$138
SSD: Lexar NM790 1TB - Bought
Case: Montech 903 Max -$86
CPU cooler: Phantom Spirit 120 Se $48
bro.. key point u did not say how much u got the 9070xt for?
blimpnuts
Hi All! Seeking advise for the below setup that i am intending to purchase. Could you kindly comment if any of the parts are incompatible or if i should upgrade to a 1000 PSU unit?
AMD RYZEN 7 7800X3D 4.2GHz 8CORE/16THREAD
TUF GAMING RADEON RX 7900XTX 24G OC
CPU Cooler: THERMALRIGHT AQUA ELITE 360 BLACK V3 ARGB
Motherboard: GIGABYTE B650 AORUS PRO AX
Memory (RAM):FORCE DELTA RGB 6000MHz 32GB(16GBx2) CL30
Storage:SAMSUNG 990 PRO 2TB GEN4
Case: LIAN LI O11 Dynamic Evo
PSU: SILVERSTONE DA850R ATX3.0 BLK 850W 80+ GOLD F.M
-Synchronicity-
hope they can come down abit like 850
Highly doubt it. Not when it's selling like hotcakes at 999 and above as proven by lack of stock islandwide for all retail price cards.
At most, if stock comes back at retail price of 999, pray there's online coupons.
NightRaven49
generally no incompatibility. see if the 9070xt costs about the same, maybe that could be a better choice. psu power capacity is fine, though the da series is so so only and for the prices u are paying for the rest of the parts, surely u can afford a higher end psu that is of higher quality with longer warranty.
blimpnuts
The 9070 xt build costs around 100 dollars lesser, but the build is slightly different
RAM: CRUCIAL PRO DDR5 BLACK 6000MT/s 32GB(16GBx2) CL36
Motherboard: ASUS TUF GAMING B650M-E WIFI MOTHERBOARD (decided to go with ASUS TUF GAMING B650-E WIFI DDR5 instead for the 7900XTX build)
PSU: THERMALRIGHT TR-SG 750 80+ GOLD MODULAR PSU
Do you feel that it is worth to get the 9070xt instead now for future proofing and lower PS?
NightRaven49
the ram and mobo are a step down, though either of these should not matter as much for the 78x3d. the xtx generally offers comparable if not slightly faster raster performance and a much increased vram capacity, though the raytracing performance of the 9070xt is significantly better; u could argue either way which is more "futureproof". if u value power efficiency, then that is another point in the 9070xts favour, and dont forget fsr4. i do feel the discount should be more than $100 though, especially due to the downgrades in other parts, otherwise ur just getting scalped.
Hello_la
Which build should or choose? Or what to change?
AMD RYZEN 5 7600 3.8GHz 6CORE/12THREAD
ASUS TUF GAMING B650M-E WIFI MOTHERBOARD $413
THERMALRIGHT ASSASSIN X 120 R DIGITAL ARGB BLACK $45
G. SKILL FLARE X5 DDR5 6000MHZ CL30 AMD EXPO Kit $185
Samsung 990 Pro Nume 2.0 7400MB/s Gen4 M.2(5yrs) $149
Seasonic Focus GX-750 (750W, 80+ Gold) $189
Fractal Design Meshify 2 Compact Blackout AT $182 or Corsair 4000D Airflow TG ATX Casing $119
Msi GeForce RTX5070 12Gb Shadow 2X OC Triple Fan GDDR7 $910x or sapphire 9070xt
AMD RYZEN 5 7600 3. 8GHz 6CORE/12THREAD ASUS TUF GAMING B650M-E WIFI THERMALRIGHT ASSASSIN X 120 R DIGITAL ARGB BLACK
CORSAIR DOMINATOR PLATINUM 6000MHZ 32GB (16GBX2) CL30
MSI GeForce RTX™ 5070 SHADOW 2X 12G SAMSUNG 990 PRO 1TB GEN4
THERMALRIGHT TR-SG750S 750W ATX3.1 80+ GOLD
$1929
paco
hi guys could you recommend me any setup from the current IT show or other places?
Basic setup will do as gaming wise only Street Fighter 6, budget <$1.3k, thanks
deepblue_82
there is some prebuild like from aftershock and invader and dreamcore depending the discounts
schoool
Hey gurus. IT show is ongoing. And I need help in deciding 3 setup.
Invaderpc - $1313
MASTER M14 | RX 7800XT | Ryzen 5 7600
AMD WRAITH COOLER
SAPPHIRE AMD RADEON PULSE RX 7800XT
CRUCIAL P3 PLUS 1TB GEN4 NVMe M.2
SILVERSTONE ET750-G 750W 80+ GOLD
SILVERSTONE LD04 BLACK ARGB TEMPERED GLASS
3 X 120MM ARGB FANS
HIGH SPEED AX WIRELESS AND BT | WIFI 6e* + BT 5.3*
WIN 11 UN-ACTIVATED
Dreamcore $1319
AMD Ryzen 7 7700 8-core
PRO B650M-A WIFI
Stock CPU Cooler
32GB RIPJAWS M5 RGB DDR5 6000Mhz (2x16GB)
NITRO+ RX 7700 XT GAMING 12GB GDDR6
SPATIUM M480 Pro PCIe 4.0 NVMe M.2 1TB
MAG A650BN
MAG PANO M100R PZ [BLACK/WHITE]
Free Games
– Monster Hunter Wilds (worth $99.99)
Aftershock
Amd combo level 4 - $1315
AMD Ryzen 5 7600 Processor
AMD Wraith Stealth Cooler
Gigabyte B650M Gaming Wifi 6E
Powercolour Radeon RX 7800XT - 16GB
32GB Patriot SL Sig DDR5 6000MHz CL32 Low Latency (16x2)
1TB Lexar NQ780 Gen4 SSD
750W Thermalright 80+ Gold
Currently siding towards Invaderpc and Dreamcore. But is it more worth going for AMD Ryzen 7 7700 but GPU RX7700 XT or Ryzen 5 7600 but RX7800XT?
Hoping for a better future proof. Thanks
Dashie
Hey guys regarding IT show do you have to go down for special deal or all of the deals are already shown as on the websites?
cockatoo777
Invaderpc - $1313
AMD WRAITH COOLER
3 X 120MM ARGB FANS
WIN 11 UN-ACTIVATED
Dreamcore $1319
PRO B650M-A WIFI
Stock CPU Cooler
MAG A650BN
Free Games
Aftershock
I went with the invaderpc option but added a simple air cooler (assassin 120). 7800xt is more valuable than the 7700 cpu imo and I don't trust Aftershock to give good components.
cockatoo777
Certain things like monitors will have discounts only visible during the show (ie. they will slash the price and you'd have to ask the promoter for the current price)
froztheart
Hi guys, been a while since I last built my own PC before the crazy gfx prices as seen below of my setup.
I don't mind getting a prebuilt since there's IT show ongoing OR just buying the parts and upgrade my exisiting rig.
Needs: Future proof for min. 5 years?
Budget: Flexible as long can last, don't mind spending.
Preference: AMD/Intel/NVIDIA is fine for CPU/GPU as long as worthwhile while maximising the cost to performance.
Usage: Gaming/Work (Dota/FPS mainly)
Monitor
24" BenQ ZOWIE XL2411P - 144Hz
Rig
Tecware Nexus Evo
ASUS ROG Strix 750 Modular 80+ Gold ATX
Intel(R) Core(TM) i5-9600K CPU @ 3.7GHz
ASUS Z390-A-PRO
NVIDIA GeForce GTX 1060 (ZOTAC) -6GB
32GB Corsair Vengeance LPX DDR4 3200 C16
1TB SanDisk SSD, 125GB ADATA NVMe SSD & 2TB Toshiba HDD
DingDang51
Hi,
I'm looking for reco to replace my PSU as warranty has expired. Budget <$100. Not sure if the price on pg1 is still valid coz Seasonic core gm seems to be OOS. Tks
My rig is as follows
Ryzen 5700x
MSI B550m Pro Vdh WiFi
Corsair Vengeance 3200 4x8GB
Lexar NM790 1TB
MSI Radeon RX6600
Thermalright Assassin X 90 SE
1 SSD
1 HDD
1 Bluray and 1 DVDRW
