Ronaldo88
- Dec 16, 2008
walao moi 200+ not called yet ..wtfWas 600+ for Bedok estate
U bid for which estate?walao moi 200+ not called yet ..wtf
BB.....。。U bid for which estate?
Go check your hdb page. Sometimes come suddenly one. If don’t have can call hdb askBB.....。。
so far only 50 units booked..so moi guess perhaps another 2-3wksGo check your hdb page. Sometimes come suddenly one. If don’t have can call hdb ask
Wow u so lucky.anybody received notification for pasir ris bto appointment so far?
Wow u so lucky.
So which facing u plan to choose?
Merpati Alcove doesn't have a rental block in it. If you're referring to 136A, that's community care apartments. It's different from the 2 room rental units (see Bayshore Vista). To put it crudely, community care units is for the aging population and 2 room rental units is for the financially disadvantaged.Am not eligible for BTO but checking out the options for a future resale. As a chao elitist mountain tortoise who has never lived around rental flats before, how bad is it to have a rental block next door? I'm pointing out Merpati Alcove where the majority of units in that project are rentals. The rental block, although a good distance away from the BTO block, is right next to the MRT and bus stops.
I'm aware that Circuit Road is full of rental flats east of the longkang, but this design puts them on the "private property" side and makes them unavoidable for anyone taking public transport. The Macpherson BTOs nearby are the opposite of this where the rental blocks are hidden away from the MRT and BTO grounds. Is Merpati Alcove an inevitable disaster and resale value wrecker for every public transport rider in the area or is it nothing to worry about?
Alamak, I never see properly that one. Saw the obvious 2-room unit size of the block layout, thought of how it's next to Circuit Road, put two and two together (and got five). I love the locations of Bayshore and Tanjong Rhu too, but those BTOs put the rental units right in the same block. Heard from others that some projects have a "lower floors rental, higher floors owned" design but if I remember correctly these projects put them on every floor. Liddat how ah? Lift will have pee and playground will have used needles, not to mention YPs loitering around common areas and smoking? Or the "social equality" idea that mixing high SES and low SES individuals evenly reduces low SES behavior actually works?Merpati Alcove doesn't have a rental block in it. If you're referring to 136A, that's community care apartments. It's different from the 2 room rental units (see Bayshore Vista). To put it crudely, community care units is for the aging population and 2 room rental units is for the financially disadvantaged.
Putting the truth here may kena NTUC points.Am not eligible for BTO but checking out the options for a future resale. As a chao elitist mountain tortoise who has never lived around rental flats before, how bad is it to have a rental block next door? I'm pointing out Merpati Alcove where the majority of units in that project are rentals. The rental block, although a good distance away from the BTO block, is right next to the MRT and bus stops.
Less drop out these days, how many more before you?amk left with 71 flats today
u guys think got chance? appt on 27 may
same as other prime loHow much for keppel golf bto
Even two room?same as other prime lo
start from $550 k
but this one maybe 10% clawback hahaha.
that is how gov keep BTO price low.
Is Still a very Good buysame as other prime lo
start from $550 k
