https://nanoreview.net/en/soc-compare/qualcomm-snapdragon-8s-gen-3-vs-mediatek-dimensity-8300Any users of Xiaoxin Pad Pro 2025 12.7 care to share hows the performance and the china rom's limitation (if any)?
saw it quite cheap at $300+, on 8300 chip![]()
Redmi pad se is given as free gift for ongoing xiaomi 15 and xiaomi 15 ultrawhat's the cheapest tablet with a nice screen for reading manga from MiHon and Netflix or some other app to watch stuff
my ipad air 10 had huge splotches
which the apple store in orchard says I have to pay 600 for fixing the screen cause the battery life is still over 90 percent
but they only fix at the discounted rate of 180
if you can get the battery life down to 80 percent
Read HWZ Forum Rules!
Been using for few weeks, mainly for steaming and media consumption. Snappy performance no complains for $300 tablet. Was looking at the redmi/poco as well but got this coz of better cpu and slightly larger screen. Take note can be a bit hefty & heavy in the hands while using. No issues with Netflix just get original CNrom.Any users of Xiaoxin Pad Pro 2025 12.7 care to share hows the performance and the china rom's limitation (if any)?
you need only 5Mbps for 1080p video streaming. Dont have to go for 5G.Nowadays many MVNO giving out obscene data plans, quite good for big screen tablet for streaming video on the move...
Any 5G tablet to intro?
Samsung galaxy Tab A9+ 5G with legacy 3.5mm headset plug was quite low priced.
But 4G memory was its downside.
depends on your usage requirementsNowadays many MVNO giving out obscene data plans, quite good for big screen tablet for streaming video on the move...
many models availableany recommendations for mobile sim models around 300+?
do u have a screen size in mind?
need 1st party keyboard support?
are you going to use it for gaming? or just basic usage?
do u need local warranty, or are u ok with brands which do not have local service centre?
Am using alldocube iplay 50 mini pro, below $200 from aliexpressno preferred screen size. basic usage. ok with non local warranty but should have google play.
Challenger on Lazada/shopee is selling Redmi pad se 4g 8.7 at $199 but can use $40 voucherAm using alldocube iplay 50 mini pro, below $200 from aliexpress
Quite a few listings, choose the official store, should be the one with relatively high sales volume, to be on the safe side
Note: no auto-brightness, but you can turn on accessibility option for quick shortcut to adjust brightness
Samsung tab a9, check amazon.sg and amazon.com to see which side cheaper. Note: this model has 2 versions, wi-fi version and 4g version.
Local warranty, can consider redmi pad se 8.7. Note, this model have 2 versions, wi-fi version and 4g version. Same precautions, buy from official store, lazada or shopee or mi.com
But 4GB ram is too small. Lag when switching apps.Just did a check, mi.com good deal for 4/64 version
https://www.mi.com/sg/product/redmi-pad-se-8-7-inch-4g/?skupanel=1&gid=4223712522
Below $120 after vouchers
Hi bro,Gotten my Xiaoxin pro pad 2025, satisfied user too at a very affordable price range
dimensity 8300 can handle gaming without issues
https://forums.hardwarezone.com.sg/threads/gpgt-sic-my-new-hoot.7112161/
Hi bro,
Want to check did u get the keyboard ?
Kinda of exp for the keyboard
