China Tablets to recommend
Devilsire
Any users of Xiaoxin Pad Pro 2025 12.7 care to share hows the performance and the china rom's limitation (if any)?
saw it quite cheap at $300+, on 8300 chip :o
leonaheidern
what's the cheapest tablet with a nice screen for reading manga from MiHon and Netflix or some other app to watch stuff
my ipad air 10 had huge splotches
which the apple store in orchard says I have to pay 600 for fixing the screen cause the battery life is still over 90 percent
but they only fix at the discounted rate of 180
if you can get the battery life down to 80 percent
Read HWZ Forum Rules!
caterham7
Redmi pad se is given as free gift for ongoing xiaomi 15 and xiaomi 15 ultra
Likely many will try to sell off
You can try checking carousell
Details of this model, low-end model, manage expectations
https://www.mi.com/global/product/redmi-pad-se/
diesel
Been using for few weeks, mainly for steaming and media consumption. Snappy performance no complains for $300 tablet. Was looking at the redmi/poco as well but got this coz of better cpu and slightly larger screen. Take note can be a bit hefty & heavy in the hands while using. No issues with Netflix just get original CNrom.
kevinlaikf
Nowadays many MVNO giving out obscene data plans, quite good for big screen tablet for streaming video on the move...
Any 5G tablet to intro?
Samsung galaxy Tab A9+ 5G with legacy 3.5mm headset plug was quite low priced.
But 4G memory was its downside.
gregory_choo
you need only 5Mbps for 1080p video streaming. Dont have to go for 5G.
better to spend money on memory, current android os needs at least 6GB , best if can get 8GB or more.
caterham7
depends on your usage requirements
aliexpress iplay 60 lite, $150 can get
https://www.aliexpress.com/item/1005007355380219.html
manage expectations, basic but should be ok for streaming video on the move
treat as no warranty as no local service centre
caterham7
any recommendations for mobile sim models around 300+?
many models available
do u have a screen size in mind?
need 1st party keyboard support?
are you going to use it for gaming? or just basic usage?
do u need local warranty, or are u ok with brands which do not have local service centre?
tomb
no preferred screen size. basic usage. ok with non local warranty but should have google play.
caterham7
Am using alldocube iplay 50 mini pro, below $200 from aliexpress
Quite a few listings, choose the official store, should be the one with relatively high sales volume, to be on the safe side
Note: no auto-brightness, but you can turn on accessibility option for quick shortcut to adjust brightness
Samsung tab a9, check amazon.sg and amazon.com to see which side cheaper. Note: this model has 2 versions, wi-fi version and 4g version.
Local warranty, can consider redmi pad se 8.7. Note, this model have 2 versions, wi-fi version and 4g version. Same precautions, buy from official store, lazada or shopee or mi.com
gregory_choo
Challenger on Lazada/shopee is selling Redmi pad se 4g 8.7 at $199 but can use $40 voucher
Devilsire
Gotten my Xiaoxin pro pad 2025, satisfied user too at a very affordable price range
dimensity 8300 can handle gaming without issues :grin:
https://forums.hardwarezone.com.sg/threads/gpgt-sic-my-new-hoot.7112161/
Devilsire
Hi bro,
Want to check did u get the keyboard ?
Kinda of exp for the keyboard
nope I didn't get the keyboard, how much is it?
I'm mainly only using at home, thus connecting via my own mechanical keyboard & mouse via via BT thru a KYM switch gadget device, switching easily for my pc, projector TV, phone & tablet etc
https://forums.hardwarezone.com.sg/...adapter-convertor-for-keyboard-mouse.6904304/
if gonna use for travel / outdoors then make more sense to get the keyboard. btw their PC mode actually looks very polished
