Desktop Chair Roundup - Ergonomic Chair
freshvibes
You can consider this $144, basically a Sihoo M57 PRO but cheaper price
https://shopee.sg/NTN-Healthy-Story...10?xptdk=bfc1b654-993a-49b1-9654-77bacd8be204
Are you using this now? Really similar to M57?
Devilsire
I'm not using this
From the users pics, the tab and knob on the chair are Sihoo M57 PRO
Exactly the same as the official Sihoo M57 PRO video
For $144 is a good buy, $118 with vouchers
i went to take a brief look...
just sharing awareness, i noticed there are many signs of fake reviews brushing from this seller store (fake photo review signs include non-local signs such as china wall plug, china label items, cheap option/variation order with review for main product etc )
of cos it'll be good if someone here willing to try and verify if actual product received will be a sihoo or exact same oem labeless :)
tigerwoods
Maybe buy from Tmall better?
https://detail.tmall.com/item.htm?i...perties=13746047:119248816;13746149:119249678
alauz
Actually I just bought and self-assembled this chair ULTi APEX Ascent Pro X5 because my Hinomi H1Pro Chair Gas Strut died. The replacement Gas Strut is on the way but after I repair it, my wife will be using it.
I gotta say, the overall chair Hinomi is better in build quality, but the weight limit is higher on this new chair I bought. The all-metal base is solid AF but the lounging leg rest cannot compete with Hinomi's. Overall, I'd give it 8/10 from first impressions. But Hinomi was a 9/10 for me when I first used it. The price difference, Hinomi retailing for $519, Apex is $389 a $130 difference.
Hinomi came fully assembled, while Apex you gotta self-assemble, the screw fitting is very tight, so it is a challenge to assemble alone. Best if 2 people, I got my wife to help and it was a lot easier.
Goodshot
i got both M57 pro and M59 pro
M57 - low back no support need to sit st8
m59 - lower back got support but upper back not much support (need to sit very deep insideto have both support)
next chair i just get aeron
@tigerwoods
Correct , i keep changing chair wasted around $200-300 for each time within 2 yrs , until i got Aeron never change after that for 6 yrs already . In long term i got better comfort , back posture and save money
bumdssa
can someone take one for the team? haha
cochran
Qns for aeron.
I have the classic aeron and plan to do some refurbishment myself.
Can i confirm the "black" color for classic aeron is called black? or graphite? or?
bladez87
I read new aeron mesh tear easily?
