deepblue_82
Hi All, i am looking to buy a desktop for secondary school children. The games they play are mainly Roblox, driving simulators and watching youtube. I have looked around and found that invader pc offers very good value for money, so much so that even if i buying the same parts from sim lim, i cant seem to achieve their prices.
Can i ask if the specs below are sufficient or is it overkill for my purpose? Many thanks for your advice.
MASTER M03 | RTX 4060 | Ryzen 5 5600​
SGD $ 785.00​
GeForce RTX™ 4060 | Ryzen 5 5600
AMD RYZEN 5 5600 3.5GHz 6CORE/12THREAD
ASUS PRIME B550M-A WIFI
AMD WRAITH COOLER
TEAM T-FORCE DELTA RGB 3600MHz 16GB(8GBx2)
ASUS DUAL GeForce RTX™ 4060 O8G TWIN FAN GDDR6
CRUCIAL P3 PLUS 1TB GEN4 NVMe M.2
SILVERSTONE VIVA 550-B 80 PLUS BRONZE 550W
SAMA M203 BLACK TG M-ATX CASE
4 X 120MM ARGB FANS
HIGH-SPEED WIRELESS AND BT
WINDOWS 11 HOME UN-ACTIVATED
MASTER M32 | RX 7600 | Ryzen 5 5600​
SGD $ 725.00​
Radeon RX™ 7600 | Ryzen 5 5600
AMD WRAITH COOLER
ASUS DUAL AMD RADEON RX 7600 O8G V2 GDDR6
SILVERSTONE LD04 BLACK ARGB TEMPERED GLASS
3 X 120MM ARGB FANS
MASTER M02 | RTX 3050 | Ryzen 5 5600​
SGD $ 685.​
GeForce RTX™ 3050 | Ryzen 5 5600
AMD WRAITH COOLER
MSI GeForce RTX™ 3050 6GB VENTUS 2X OC
4 X 120MM ARGB FANS
https://armaggeddonpc.com/collectio...5-5600-rx-6600-gaming-pc-16gb-rgb-ram-1tb-ssd
https://armaggeddonpc.com/collectio...ts/thunder-r5-5600-rtx-4060-same-day-delivery
cheaper here abit u also can pay installment
deepblue_82
Is Armageddon quality ok? They never list the brand model of the parts used so I guess they using cheaper parts?
for reals i dont know... everything is still ok.. but its just the psu... i am not sure...
deepblue_82
SGD $ 785.00​
AMD WRAITH COOLER
4 X 120MM ARGB FANS
SGD $ 725.00​
AMD WRAITH COOLER
3 X 120MM ARGB FANS
SGD $ 685.​
AMD WRAITH COOLER
4 X 120MM ARGB FANS
i see a few on carosell.. between 250-350 for a i5 9700k or a amd 3600 both with gtx 1080ti...
100% can play and watch youtube...
coz i dont think the students will take care of the pc... so no point spending that amount
NightRaven49
just avoid them. u spend so much money on their pcs but dont even know what parts they offering, does not sound like a good idea to me. especially the psu, not worth saving that little money vs more legit brands to risk all ur expensive parts being fried if the psu chibaboom.
deepblue_82
ok @NightRaven49 bro has spoken...........
Vanyel
would suggest diy better no?
get a better MB+CPU and PSU so in future upgrades these 3 parts no need to touch
deepblue_82
then he has to troubleshoot when ever something happens...
but u know school kids.. go everywhere press everything.....
Vanyel
Secondary sch liao right?
My kids dun really anyhow mess with the cpu
Also its good to give them some basic knowledge also
Every time i fix up things for them, i will get them to do it together and also explain whats going on
Ridiculous
Hi, I’m looking to buy a pc and need help/recommendations as it’s my first one. Currently using a Lenovo legion laptop but it’s past warranty and seems to be having some issues so I thought it might be a good time to change.
I don’t have any knowledge on hardware and would assume buying a prebuilt one would be a better choice than a diy? The most graphic intensive game I’ve played would probably be lost ark so specs good enough for around there should be fine for me.
looking at aftershock as some have recommended in the thread but there’s so many options available. I can include my current laptop specs if anyone would like to know so they can help recommending something. My laptop was built based on recommendations from hwz previously as well.
NightRaven49
depends on what u mean by better. prebuilts generally offer good performance for the money u spend, but may cut corners to hit that lower price point. diy means u can choose higher quality parts to hopefully have them last longer, and can also tailor more closely with ur needs.
cheap system with a 4060/b580 should be more than enough.
Ridiculous
Would you have recommendations on what to get if the budget is below $3k? Looking to get something that can also allow me to play triple A titles moving forward. Is the recommendations on the first post still valid or are there better options to look at now?
SirusWhite
Hi, does anyone have any experience with buying Boxed AMD CPU from Taobao? Specifically the ones with CBX product code at the end.
I’ve been trying to research and some say it’s covered by international warranty, Some say it’s only within China.
Thanks!
Vanyel
Thanks!
U try msging the taobao shop ask?
They generally reply very fast
Vanyel
3k can get very good higher mid tier specs liao
Ridiculous
i got recommendations from a shop for around this price range, almost everything is the same except for these 2 items.
option1:
CPU - ryzen 7 7700
PSU - THERMALRIGHT 850W GOLD RATED PSU / ATX 3.0 / PCIE GEN 5
option2:
CPU - RYZEN 7 7800X3D
PSU - Superflower LEADEX VI Platinum PRO 850W Full Modular - PCIe 5.1 (BK)
option 2 is $400 more expensive, i'm wondering if there's a need to get the ryzen 7 7800x3d or if there are recommendations of a more worthwhile option? GPU for both is RTX 5070TI ZOTAC SOLID OC. any advice or suggestions is welcome, thanks alot!
tk
option1:
CPU - ryzen 7 7700
option2:
Actually I thought this $1.8k m59 set would be good enough for your purpose...
https://www.invaderpc.com/product/specm59/
Vanyel
option1:
CPU - ryzen 7 7700
option2:
think can save the 400 for other stuffs like 4tb nvme
jas663
I'd bot MSI B550M Pro-Vhd from Tradepac previously, the HDMI port is spoilt, used about 1.5years. But I heard if there is no corbell sticker on the Mobo mean no warranty? Is it true? The shop told me got 3 yrs warranty.
Does MSI provide repair or replacement?
I have tried using 3 HDMI cable but all not working, VGA cable do work though, so my monitor is not the issue.
2 monitors all cannot work on the HDMI port.
