Are Singaporeans Diet unhealthy?
ctan84
I find this recommendation reasonable. For heart health, the American Heart Association and the Dietary Guidelines for Americans recommend eating at least two servings (about 8 ounces) of fatty fish per week, with one portion being oily fish.
I have never met anyone that managed to hit even the 1:4 ratio. I tried before but faced many issues. In the end unable to even evaluate the benefits. I found that even refrigerated flax seeds oil turn rancid pretty quickly after opening. I never tried enough flaxseed meals to get that ratio as you have mentioned our food supply is mostly omega 6.
If it is just to avoid deficiency, probably 1-2 standard 120/180 fish oil capsules a day will do. For significant mental sharpness, research indicate 1500mg of DHA daily, I would think 500mg will probably be beneficial already. DHA has functional benefits in cognitive function and against depression. There was a time when a pharmaceutical giant wanted to patent DHA but can't because it is a naturally occurring substance. EPA is the omega 3 fatty acid that gives rise to the anti inflammatory series prostaglandins. I won't take lots of 180/120 caps because there are some research that indicates certain health risk.
Isn't there emerging research to show that mega doses of omega 3 can reduce overall inflammation in the body?
Ironside
Flaxseed has ALA that body needs to convert to EPA DHA. Not efficient. But still a possible non ocean source. Usually for those with sensitivity or allergy to sea based food.
The effect of ratio of omega 3 to 6 is not limited to prostaglandins. Fatty acids are incorporated into our cell membrane. ALA Omega 3 will increase fluidity and flexible e.g. reduce blood pressure. The increased fluidity could made receptors more mobile e.g. increase insulin sensitivity.
The risk of high intake of fish oil capsules I have already mentioned. High seafood intake also comes with the risk of consuming too much heavy metals and pollutants like PCB etc.
Evil_Boss
Checkyrmed
The average hawker meat compared to carbs. Ban nian, chicken rice, hokkien mee, etc are all heavy on carbs. Ask for more meat cost money.
The amount of greens too are low with nutrients after heavily cooked.
I don't believe in such thing as healthy fats. Watch you fat intake be it good or bad etc
Cut down on fats and carbs, eat more veg and meat.
That's just my opinion when I eat out.
If you are not seeing improvements in your metabolism or weight loss despite consuming adequate healthy fats, it is advisable to consult a good and experienced physician who can provide tailored medical advice.
Checkyrmed
Cell membranes require a balanced mix of saturated and unsaturated fatty acids to maintain both fluidity and stability. Relying too heavily on unsaturated fats can make the membrane overly fluid and permeable, leading to unintended leakage of ions and small molecules. This excessive fluidity also reduces mechanical robustness, making cells more susceptible to physical stress. Crucially, unsaturated fatty acids are prone to oxidation, generating toxic by‑products that compromise membrane integrity and overall cell health.
An overabundance of unsaturated lipids can disrupt specialized membrane microdomains known as lipid rafts, which are vital for proper signaling and protein function. Changes in membrane thickness and lateral pressure can impair receptor and enzyme activity, altering critical cellular processes. In epithelial barriers, such as the gut lining or blood–brain barrier, overly fluid membranes may weaken tight junctions, increasing vulnerability to pathogens and toxins. Thus, while unsaturated fats are essential, they must be balanced with saturated fats and cholesterol to ensure optimal membrane function and cellular resilience.
The main takeaway is oxidation from the unsaturated fat: the last thing you want is a cell membrane that’s easily damaged by oxidative stress,your cell membranes must resist oxidative damage to protect your cells.
Ironside
U look at our hawker food u noes liao
I ever heard a very famous curry chicken noodle hawker on TV slipping out of his tongue, he used a lot of chicken powder to make his curry soup flavourful. After that I never eat at that stall again. I will be curious to know how much sodium his serving contains.
SpeedingBullet
If he never went on TV you'd still be eating it right?
That's the key problem with sinkies and rise of diabetes/CKD/ASCVD - high tolerance for ultra high sugar/sodium until your tongue can't tell the difference. Btw sodium isn't exactly bad for you if you're exercising regularly (sweating alot is key) and don't have blood pressure problems
Ironside
It is far from my place. Maybe once in a while if I do not know.
SpeedingBullet
Yeah figured. Unfortunately, I don't think that particular hawker is a rarity, most, if not all hawkers put a lot of sh1t in their food. But if your health is generally OK, sodium is fine, it's more the carbs (sugar) you gotta worry about
Full_Cream_Milk
Heng I totally avoid hawker because of its dirtiness
And unhealthy food.
Ironside
His food taste very flavourful compared to others. That is a clear sign.
Too much sodium is definitely bad. I do not take more than 1500mg a day.
SpeedingBullet
Too much of anything is bad, I'm just saying, sodium isn't the monster the govt is trying to paint it to be esp. if you're a healthy individual.
Wow I'm far north of 2500mg a day.
cyke69sg
Talking about healthy food is one thing.
But in SG another big topic is good to eat or not? Tasty? Often hear SGrean say this food CMI that food CMI.
Do the very health conscious ones avoid eating out in SG?
Maybe you guys can recommend some places with tasty good to eat healthy food for outings ?
@Checkyrmed do such places exist in SG?
@Ironside @rogze79
