Fundsupermart's FSMOne $8.8 flat fees
Eternit
I thought FSMOne charges a flat fee of S$8.80 for local stocks. Was tempted to buy some DBS stock, the estimate fees is S$11.66, why?
Screenshot:
sibeiTrolled
You can open a email support with FSMOne, they can better answer you.
Just in case you didnt know.
https://secure.fundsupermart.com/fsm/new-to-fsm/pricing-structure
Flat processing fee does not include 'Other charges incurred by respective Exchanges' (refer to section below), and is subjected to trade amalgamation conditions. For non- SGD transaction, it is also subjected to the minimum processing fees of the respective currency.
8.80 is just what FSMONE is charging you, there is exchange clearing fee and GST as well.
And also, that is estimated fees. May be higher, may be lower.
lucky_
Anyone used SRS funds to purchase ETF RSPs? Thinking of using the spare pockets of SRS money to buy STI ETF RSP (currently advertised as 0% processing fees) but not sure whether there are any drawbacks. Some questions I have:
1. Will the RSP lots be held in SRS bank or in FSMone?
2. Selling possible via RSP (fractionated lots)?
3. Fees for selling (both whole lots and fractionated lots)?
Thanks for advising!
fr33d0m
1. SRS Bank, got extra fee from SRS Bank
2. since it is SRS Bank, should be any broker linked to your SRS Bank
3. up to the broker you use
lucky_
Thanks very much! Sounds like it is not worth it then, if there are extra fees from SRS Bank (presumably every time the RSP is processed?)
sibeiTrolled
You are saying fsmone has the lowest commission?
Assuming you have 15K SGD to invest.
Let us ignore the exchange fee (which is to be paid to SGX in this case).
Base on FSMOne fee structure, you will only pay 8.80 SGD
https://secure.fundsupermart.com/fsm/new-to-fsm/pricing-structure -Select Stocks
Assuming you are looking at Moomoo or Tiger, there are 2 fees you have to pay, both Comission and Platform Fee. Both are 0.03% * Trade Value
Let us also ignore the exchange fee (which is to be paid to SGX in this case).
Comission: 15,000 * 0.03% = 4.5 SGD
Platform fee: 15,000 * 0.03% = 4.5 SGD
https://www.itiger.com/sg/commissions#singapore_stocks
https://www.moomoo.com/sg/broker-about/pricing - Select SG and click More
Higher buy in amount, FSMOne has the advantage due to fixed fees
Lower buy in amount, % based brokers has the advantage.
Break even in this case is around 14,666.67
Joseph99
Hi all , was there revision in charges for rsp ? I been rsp es3 etf. The fees increased from.0.46 to 0.86..Amy idea why ?
