ZacharyA
- Apr 11, 2010
If you look at a physical Armaflex insulator, how you know its 1/4, 1/2 or 3/4? For me, I use ruler to check the thickness.
How about the copper coil, how you know its SWG 21 or 22? I only saw this written on the LHCT Package 06.35x0.81-15m.
Oh wait, Coolserve guy just reply and told me 0.81 mean SWG 21.
My account cannot upload photo.
It is usually written on the outer layer of the insulation. The dimensions and specifications.
For copper pipe, unless they bring balanced coil (used halfway). They will most definitely bring new ones as well (3-4 bundles or more depending how many FCUs you installing. The brand new copper pipes have a white stick on it labelling its specifications as well.
If you are not physically there at the day of installation, you can request installer to take pic and show you before installation.
Unless of course you afraid he take picture of 1, and use a lower grade when installing (which is unlikely but not impossible), then you better schedule a day where you can be at home to supervise.
