CPTMiller
- Nov 2, 2000
I believe they only utilize the package on 4G network. Definitely Speed is slower as more users increasingeight no plan to offer 5G?
If you can use 4G+ maybe faster speed.![]()
Manage to switch to Band 3, now speed is better
Code:4G Cellular Information Detail EARFCN 1600 Band 3 Bandwidth 20 MHz Physical cell ID 104 RSRP -98 RSRQ -12 SINR 3.5
Unfortunately my side cannot find any 4G+ cell signalIf you can use 4G+ maybe faster speed.
Down 33Mbps Up 4Mbps is equivalent to TPG Simba speed.
Go to one of the service centres to get a SIM card replacement? It's still FOC now. Just bring your ID along.Can I check with you guys what are the steps to take in the event if I lose my phone? Eight is to wait for them to open and go down to the service center and to do a replacement? Since there is no number to call, and they take some time to reply to emails, I'm a little concerned if I lose my phone especially outside their opening hours or overseas, because I can't call to suspend the line immediately, although is this a common step to do even with other telcos, to suspend the line? I think esim maybe not so crucial, but physical might be a problem.
Actually what I am worried of is if I am overseas, what's the best course of action if I am using physical sim? I'm afraid the finder will abuse the number.Go to one of the service centres to get a SIM card replacement? It's still FOC now. Just bring your ID along.
Actually I'm what I am worried of is if I am overseas, what's the best course of action if I am using physical sim? I'm afraid the finder will abuse the number.
So I know what to do if it happens. Accidents do happen, be it theft or what not.when it happens it happens why worry before hand? are you planning to loose uout phone ?
IMO, make a police report if you're worried it'd be misused illegally. Otherwise, PM them in FB and also send them an email.Actually I'm what I am worried of is if I am overseas, what's the best course of action if I am using physical sim? I'm afraid the finder will abuse the number.
1-2mbps ? omg worst than simbaonly 1 to 2 mb at North East now?
how is the speed at your place
My side normally get 4G+ signal but will change to 4G about midnight till morningUnfortunately my side cannot find any 4G+ cell signal
which area is this.Wa the speed jialat
Sounds like the base station in power saving mode........My side normally get 4G+ signal but will change to 4G about midnight till morning
Yes all along like this. since eight 1st started till now. i posted about this before. 4G+ becomes 4G nearing midnight till morning.My side normally get 4G+ signal but will change to 4G about midnight till morning
Same. Went in yesterday and encountered E at the start though it got better subsequently.encountered a lot of spots with weak 4G connections, and also spots where it is non-existent at all (only EDGE connection)
Ya, friend on some other telco couldn't connect on his phone till he had to forcefully downgrade to 4G then it works.Don't think it's the fault of Eight, more like issues with the mobile infra there
