[best Headphone for your money] ugreen studio pro 48dB anc ldac bluetooth & wired headphone
BlackWing1977
Interesting the ear pads on the Max 5C which I assume same as the new one TS bought, uses a attach system kinda like Philips SHP9500.
trupurple
I use QCY. I steer clear of the regular brands and stick to China ones, value for money and sounds better. Just like my camera flash/lighting equips.
And I'm an audiophile enthusiast.
It's like paying SGD800 for a Canon flash VS SGD120 for Godox. And Godox perform better too (been there done all that)
elephantscannotfly
my search for good replacement headphones has ended. one of my kids has a sony wh-1000xm5 (foc). i tested it for over 30mins. the sound driver was hot and my ears felt uncomfortable wearing it for extended periods. sony sounded good but ugreen didn't have the hot driver issue, so it feels more pleasant. the ANC feature on ugreen has 3 options: 1. ambient sound 2. anc off 3. anc on. when ambient sound is on, you can hear your surrounding clearly. it further amplifies the sound giving you superpowers to eavesdrop on conversations. when anc is off, there is no amplification. and when anc is on, it shuts out noise as well as the sony
another advantage for those who broke their sony WH-1000xm5. the headband is made of metal (< 2 ohms resistance) and the ear cup connectors are made of thick plastic (1 MegaOhm) that allows the ear cup to fold inwards and turn sideways, so the risk of breakage is low
i ordered several of this headphones online for $54 each & all were given away after testing. equalizer and firmware updates are done via the ugreen home app
Hey wow, thank you for the recommendation, my sony wh-1000xm5 also just recently chibabom, not so keen to repair, or spend a couple hundreds more for new. Its like you read my mind.
BlackWing1977
Actually the better alternative I think is cheap IEM from China paired with a ANC wireless adapter. Modular and cheaper, dun like the sound of the IEM or want to upgrade sound, just replace the IEM lor. The battery in the adapter died... just replace the adapter lor.
BlackWing1977
Wow but are ear pads on sale?
Need to google lor... for this type of non-mainstream one.. you need to really search for it... as for the more mainstream brand like Sennheiser, Audio-Technica or Beyer Dynamics, those usually will have people make the ear pads upgrade for it.
windwaver
Any IEM recommendation?
li9ht5peed
I have that, good for runs, sound quality so so.
you need to push the ear buds deeper into the ear canals. and you will realize this cheap SBC ear bud rivals more expensive AAC ear buds. it's so small and light. i love it!
Loser
First time hear of anc wireless adapter. Do you have an example of a good one?
BlackWing1977
Depends on your budget lor... but ANC wireless adapter right now like not very good though. But because of the IEM nature of sealing your ear.. probably the physical isolation should help a little.
