BlackWing1977
- Mar 1, 2006
Interesting the ear pads on the Max 5C which I assume same as the new one TS bought, uses a attach system kinda like Philips SHP9500.
I think it is very new maybe on Alixpress or somethinginteresting
strangely I can't find it in 淘宝.
shopee price around 90 bucks...
Hey wow, thank you for the recommendation, my sony wh-1000xm5 also just recently chibabom, not so keen to repair, or spend a couple hundreds more for new. Its like you read my mind.my search for good replacement headphones has ended. one of my kids has a sony wh-1000xm5 (foc). i tested it for over 30mins. the sound driver was hot and my ears felt uncomfortable wearing it for extended periods. sony sounded good but ugreen didn't have the hot driver issue, so it feels more pleasant. the ANC feature on ugreen has 3 options: 1. ambient sound 2. anc off 3. anc on. when ambient sound is on, you can hear your surrounding clearly. it further amplifies the sound giving you superpowers to eavesdrop on conversations. when anc is off, there is no amplification. and when anc is on, it shuts out noise as well as the sony
another advantage for those who broke their sony WH-1000xm5. the headband is made of metal (< 2 ohms resistance) and the ear cup connectors are made of thick plastic (1 MegaOhm) that allows the ear cup to fold inwards and turn sideways, so the risk of breakage is low
i ordered several of this headphones online for $54 each & all were given away after testing. equalizer and firmware updates are done via the ugreen home app
Actually the better alternative I think is cheap IEM from China paired with a ANC wireless adapter. Modular and cheaper, dun like the sound of the IEM or want to upgrade sound, just replace the IEM lor. The battery in the adapter died... just replace the adapter lor.Hey wow, thank you for the recommendation, my sony wh-1000xm5 also just recently chibabom, not so keen to repair, or spend a couple hundreds more for new. Its like you read my mind.
So can only buy from AliExpress right?Buy from AliExpress $50.62 ah?
Need to google lor... for this type of non-mainstream one.. you need to really search for it... as for the more mainstream brand like Sennheiser, Audio-Technica or Beyer Dynamics, those usually will have people make the ear pads upgrade for it.Wow but are ear pads on sale?
Any IEM recommendation?Actually the better alternative I think is cheap IEM from China paired with a ANC wireless adapter. Modular and cheaper, dun like the sound of the IEM or want to upgrade sound, just replace the IEM lor. The battery in the adapter died... just replace the adapter lor.
you need to push the ear buds deeper into the ear canals. and you will realize this cheap SBC ear bud rivals more expensive AAC ear buds. it's so small and light. i love it!I have that, good for runs, sound quality so so.
AliExpress. i ordered around $10k of stuff from them last yearBro where you find it going for $50+?
10k buy what siaAliExpress. i ordered around $10k of stuff from them last year
AliExpressinteresting
yes!Watch ahem video got surround sound?
Why you give away? I want one too can? lol.yes!
First time hear of anc wireless adapter. Do you have an example of a good one?Actually the better alternative I think is cheap IEM from China paired with a ANC wireless adapter. Modular and cheaper, dun like the sound of the IEM or want to upgrade sound, just replace the IEM lor. The battery in the adapter died... just replace the adapter lor.
sure if you are my child, gf or wifeWhy you give away? I want one too can? lol.
Depends on your budget lor... but ANC wireless adapter right now like not very good though. But because of the IEM nature of sealing your ear.. probably the physical isolation should help a little.Any IEM recommendation?
